Preprocessor directive
tonio
I use ifort and pgf90, mainly ifort.
I also use preprocessor directives as -D, the problem is that the source code required to use a directive is different between ifort and pgf90.
For instance, ifort needs
!DEC$ IF DEFINED (FOO)
!DEC$ END IF
but pgf90 needs
#ifndef FOO
#endif
Is there a way to have a source code that would compile with both compilers ?
Thx.
ifort supports the cpp-style directives too. You can add -fpp on the line or name the file with .F or .F90 file types.
tonio
Many Thx !
It's ok now.
There's only a minor difference, a module which is encapsulated in such a directive won't compile.
I have to put the directive inside the module definition keywords :
does not compile with -fpp style :
#IFDEF FOO
module FOOFOO
end module FOOFOO
#ENDIF
this one is ok :
module FOOFOO
#IFDEF FOO
#ENDIF
end module FOOFOO
Our compiler does not like it if a source file has no compilable lines.
tonio
But it just works ok with !DEC$ style directives !
Thx again.
I know. The !DEC$ directives are processed by the compiler directly, whereas the # directives are run through a preprocessor. I'm just explaining what happens, not trying to rationalize it!
