Press any key to continue...
Help
I am running an executable using Intel Fortran compiler. At the end I get a message asking for "Press any key to continue. . ." Is there a way that i can get rid of the message and come out of the executable once it is done without pressing any key?
Thanks in advance for help
You will see that only if you run the program from within Visual Studio using "Start without debugging". If you run it from outside VS, or start with debugging, the prompt will not appear. If the prompt was not there, the console window for your application would disappear and you would not be able to see the output.
Help
Quoting - Help
Hi Steve,
Thanks for the reply. It worked
