Printing Bitmap
myron_r
I am using VF6.5, windows application. I display an image on the screen using OpenGL. Now I want to print it to a printer. When I use the following code the image prints out black. One of my problems is not understanding the structure of BITMAPINFO. I am not sure how to make the array of RGBQUAD structures, bmiColors(1) that specify the red, green, and blue intensities. There may be other things wrong with the code. I would appreciate any help that I can get.
Myron
subroutine PrintDIBbitmap(hdcbitmap) !hdcbitmap is the handle to the bitmap on the screen
use xftgdi
use VarGlob
use dfopngl
use comdlg32, only: PrintDlg, CommDlgExtendedError, T_PRINTDLG, PD_ALLPAGES, PD_RETURNDC, &
PD_NOPAGENUMS, PD_RETURNDEFAULT, PD_NOSELECTION
use gdi32, only: DeleteDC, StartDoc, StartPage, EndDoc, EndPage, TextOut, &
GetDeviceCaps, GetTextExtentPoint32, GetTextExtentExPoint, &
CreateFont, SelectObject, DeleteObject, ResetDC, SetBkMode,&
DM_ORIENTATION, DM_DUPLEX, DM_IN_BUFFER, DM_OUT_BUFFER, &
PHYSICALOFFSETX, PHYSICALOFFSETY, HORZRES, VERTRES, &
LOGPIXELSX, LOGPIXELSY, T_DOCINFO, T_SIZE, T_DEVMODE, &
DMORIENT_PORTRAIT, DMORIENT_LANDSCAPE, TRANSPARENT, &
FW_NORMAL, ANSI_CHARSET, OUT_DEFAULT_PRECIS, &
CLIP_DEFAULT_PRECIS, DEFAULT_QUALITY, &
DEFAULT_PITCH, FF_DONTCARE, PRINTER_ACCESS_USE, T_PRINTER_DEFAULTS
use kernel32, only: GetLastError, MulDiv, GlobalLock, GlobalUnlock, GlobalFree, &
GetProfileString
use user32, only: GetForegroundWindow
use winspool, only: OpenPrinter, ClosePrinter, DocumentProperties
use dfwinty, only: NULL, TRUE, FALSE, MAX_PATH, ERROR_NO_ERROR
use dfwina
implicit none
integer(4) nRet,bitmap
type(T_PRINTDLG) :: PRINTDLG_Struct
type(T_DOCINFO) :: DOCINFO_Struct
type(T_SIZE) :: SIZE_Struct
type(T_DEVMODE) :: DEVMODE_Struct
type(T_PRINTER_DEFAULTS) :: PrtrDef
type(T_BITMAPFILEHEADER) bmfh
type(T_BITMAPINFOHEADER) bmih
type(T_BITMAPINFO) bmi
type(T_BITMAP) bm
type (T_RGBQUAD) bmiColors(1) !not sure how to get this array of RGBQUAD values
type(T_RECT) rect
integer hFont,hOldFont, hPrinter, hOldDC
integer PrinterXoffset,PrinterYoffset,page_width,page_height,pixels_per_inch_x,pixels_per_inch_y
integer line_height, current_x, current_y, initial_x, initial_y
integer max_y, line_width, font_height
pointer (p_DEVMODE, DEVMODE_Struct)
! Declare default values and local variables for optional arguments
logical(4), parameter :: DDefault_Printer = .TRUE. ! Use default printer?
logical(4) :: WDefault_Printer
real(4), parameter :: Dline_spacing = 1.0 ! Multiplier by line height of line spacing
real(4) :: WLine_Spacing ! Local variable
real(4), parameter :: Dhoriz_margin = 0.5 ! Left and right margins in inches
real(4) :: WHoriz_margin
real(4), parameter :: Dvert_margin = 0.5 ! Top and bottom margins in inches
real(4) :: WVert_Margin
integer(4), parameter :: DTab_stop = 4 ! Tab column width
integer(4) :: WTab_stop
integer(4), parameter :: DPoint_Size = 0 ! Point size (0=Default)
integer(4) :: WPoint_Size
integer anull,bnull
character*33, parameter :: Dfont = "Courier New"C ! Font
character*33 :: Wfont
logical(4), parameter :: DFortran_CC = .FALSE. ! Fortran carriage control?
logical(4) : : WFortran_CC
character*516 line
character*1024 buffer
character*128 DefaultPrinterName
character*15 document_name
integer(4) line_len,substr_pos,substr_width,nLen
integer(4) column, i,j,ret
logical(4) top_of_page,Opened
character*10 formatted,sequential
integer(4) IOS
character*3 PrintingTextDocument
integer(4) vp(4),width,height,NumPixelPerInchXdir,NumPixelPerInchYdir,bmsize,rdim,rdimdw,rdimbm
integer(4) hbmComp,hbmold,hdcComp,retint,PaperWidthPixels,PaperHeightRasterLines,MaxWidth,MaxHeight
integer(4) retcod,last_error,ScreenDC,ScreenWidthPixels,ScreenHeightRasterLines
integer(4) hDCPrintDLG,busy,oldcursor,hdcbitmap
integer(1), allocatable :: bmbits(:,:),bmrow(:)
integer iw,IOrient
real(8) ScaleFactorX,ScaleFactorY
integer(4) ScaleFactorColumn,ScaleFactorRow,ppix,ppiy,brush
character DiLine*20
integer(4) ih,jw,kw,pixelrgb,xleft,ytop,BitmapWidthPixels,BitmapHeightRasterLines,PrinterWidthPixels,PrinterHeightRasterLines
integer(4) NumPixelPerInchXdirBitmap,NumPixelPerInchYdirBitmap,NumPixelPerInchXdirPrinter,NumPixelPerInchYdirPrinter
integer(4) xsize,ysize,xoffset,yoffset,rgbval,Numbercolors
IOrient=2 !landscape
IOrient=1 !portrait
PRINTDLG_Struct%lStructSize = SIZEOF(PRINTDLG_Struct)
PRINTDLG_Struct%hwndOwner = GetForegroundWindow()
PRINTDLG_Struct%hDevMode = NULL
PRINTDLG_Struct%hDevNames = NULL
PRINTDLG_Struct%hDc = NULL
PRINTDLG_Struct%Flags = PD_ALLPAGES .OR. PD_RETURNDC .OR. PD_NOPAGENUMS &
.OR. PD_NOSELECTION
PRINTDLG_Struct%nFromPage = 1
PRINTDLG_Struct%nToPage = 1
PRINTDLG_Struct%nMinPage = 1
PRINTDLG_Struct%nMaxPage = 1
PRINTDLG_Struct%nCopies = 1
PRINTDLG_Struct%hInstance = NULL
PRINTDLG_Struct%lCustData = NULL
PRINTDLG_Struct%lpfnPrintHook = NULL
PRINTDLG_Struct%lpfnSetupHook = NULL
PRINTDLG_Struct%lpPrintTemplateName = NULL
PRINTDLG_Struct%lpSetupTemplateName = NULL
PRINTDLG_Struct%hPrintTemplate = NULL
PRINTDLG_Struct%hSetupTemplate = NULL
! Bring up the Print dialog box and allow user to select printer
Last_Error = PrintDlg (PRINTDLG_Struct)
hDCPrintDLG=PRINTDLG_Struct%hDc
if((IOrient.eq.1).or.(IOrient.eq.2))then
P_DEVMODE=GlobalLock(PRINTDLG_Struct%hDevMode )
DEVMODE_Struct%dmOrientation=2
if(IOrient.eq.2)DEVMODE_Struct%dmOrientation=1
Last_Error=ResetDC(PRINTDLG_Struct%hDevMode,DEVMODE_Struct)
Last_Error=GlobalUnlock(PRINTDLG_Struct%hDevMode)
endif
!screenwidth and screenheight are width and height of screen in pixels
width=.99*screenwidth
height=.95*screenheight
bmsize = width*height*3
rdim = width*3 !bitmap file always saved as 24 bit bitmap
rdimdw = rdim !row dimension ending on a dword boundary
if (MOD(rdimdw,4) .ne. 0) rdimdw = rdimdw+4-MOD(rdimdw,4)
!-- Get pixel information
BitmapWidthPixels=GetDeviceCaps(hDCbitmap,HORZRES)
BitmapHeightRasterLines=GetDeviceCaps(hDCbitmap,VERTRES)
PrinterWidthPixels=GetDeviceCaps(hDCPrintDLG,HORZRES)
PrinterHeightRasterLines=GetDeviceCaps(hDCPrintDLG,VERTRES)
NumPixelPerInchXdirBitMap = GetDeviceCaps(hDCbitmap,LOGPIXELSX) !no of pixels/inch, x-dir
NumPixelPerInchYdirBitMap = GetDeviceCaps(hDCbitmap,LOGPIXELSY) !no of pixels/inch, y-dir
NumPixelPerInchXdirPrinter = GetDeviceCaps(hDCPrintDLG,LOGPIXELSX) !no of pixels/inch, x-dir
NumPixelPerInchYdirPrinter = GetD eviceCaps(hDCPrintDLG,LOGPIXELSY) !no of pixels/inch, y-dir
Numbercolors=GetDeviceCaps(hDCPrintDLG,NUMCOLORS)
!-- Create compatible DC and get bitmap
hdcComp = CreateCompatibleDC(hDCbitmap)
hbmComp = CreateCompatibleBitmap(hDCbitmap,Width,Height)
hbmold = SelectObject(hdcComp,hbmComp)
retint = BitBlt(hdcComp,0,0,width,height,hdcbitmap,0,0,SRCCOPY)
retint = GetObject(hbmComp,24,LOC(bm))
if (bm%bmBitsPixel .eq. 24) then
rdimbm = rdim !row dimension ending on a word boundary
if (MOD(rdimbm,2) .ne. 0) rdimbm = rdimbm+1
else if (bm%bmBitsPixel .eq. 32) then
rdimbm = width*4
else
retint = MessageBox(NULL,'Display properties not supported, bitmap not saved'C, &
'Under Display Properties, set Color Palette to True Color'C,MB_OK+MB_ICONEXCLAMATION)
retcod = 0
go to 900
end if
allocate(bmbits(rdimbm,height))
retint = GetBitmapBits(hbmComp,rdimbm*height,LOC(bmbits))
!-- Create bitmap file header
bmfh%bfType = 'BM'
bmfh%bfSize = SIZEOF(bmfh)+SIZEOF(bmih)+rdimdw*height
bmfh%bfReserved1 = 0
bmfh%bfReserved2 = 0
bmfh%bfOffBits = SIZEOF(bmfh)+SIZEOF(bmih)
!-- Create bitmap info header
bmih%biSize = SIZEOF(bmih)
bmih%biWidth = width
bmih%biHeight = height
bmih%biPlanes = bm%bmPlanes
bmih%biBitCount = MIN(24,bm%bmBitsPixel)
bmih%biCompression = BI_RGB
bmih%biSizeImage = rdimdw*height
bmih%biXPelsPerMeter = NINT(NumPixelPerInchXdirBitmap/0.0254) !(1 inch = 0.0254 m)
bmih%biYPelsPerMeter = NINT(NumPixelPerInchYdirBitmap/0.0254) !(1 inch = 0.0254 m)
bmih%biClrUsed = 0
bmih%biClrImportant = 0
bmi%bmiHeader%biSize = SIZEOF(bmih)
bmi%bmiHeader%biWidth = width
bmi%bmiHeader%biHeight = height
bmi%bmiHeader%biPlanes = bm%bmPlanes
bmi%bmiHeader%biBitCount = MIN(24,bm%bmBitsPixel)
bmi%bmiHeader%biCompression = BI_RGB
bmi%bmiHeader%biSizeImage = rdimdw*height
bmi%bmiHeader%biXPelsPerMeter = NINT(NumPixelPerInchXdirBitmap/0.0254) !(1 inch = 0.0254 m)
bmi%bmiHeader%biYPelsPerMeter = NINT(NumPixelPerInchYdirBitmap/0.0254) !(1 inch = 0.0254 m)
bmi%bmiHeader%biClrUsed = 0
bmi%bmiHeader%biClrImportant = 0
DiLine='MyronBitmap'
IW=LEN_TRIM(DiLine)+1
DiLine(IW:IW)=CHAR(0)
DOCINFO_Struct%cbSize = SIZEOF(DOCINFO_Struct)
DOCINFO_Struct%lpszDocName =LOC(DiLine)
DOCINFO_Struct%lpszOutput = NULL
DOCINFO_Struct%lpszDatatype = NULL
DOCINFO_Struct%fwType = 0
! I know the following is wrong. I am not sure how to specify bmi%bmiColors
do ih=height,1,-1
do iw=1,width
rgbval=getpixel(hdcComp,iw,ih)
bmi%bmiColors(1)%rgbBlue=ibits(rgbval,3,2)
bmi%bmiColors(1)%rgbGreen=ibits(rgbval,5,2)
bmi%bmiColors(1)%rgbRed=ibits(rgbval,7,2)
bmi%bmiColors(1)%rgbReserved=0
end do
enddo
Last_Error=SetMapMode(hDCPrintDLG,MM_TEXT)
Last_Error = StartDoc (hDCPrintDLG,DOCINFO_Struct)
Last_Error = StartPage (hDCPrintDLG)
rect%top=0
rect%left=0
rect%right=GetDeviceCaps(hDCPrintDLG,HORZRES)
rect%bottom=GetDeviceCaps(hDCPrintDLG,VERTRES)
hbmComp = CreateCompatibleDC(hDCPrintDLG)
bitmap=CreateDIBSection(hDCPrintDLG,bmi,DIB_RGB_COLORS,LOC(bmbits),Null,Null)
Last_Error=SelectObject(hbmComp,bitmap)
! scale and center on page
xsize=rect%right
ysize=xsize*bmi%bmiHeader%biHeight/bmi%bmiHeader%biWidth
if(ysize.gt.rect%bottom)then
ysize=rect%bottom
xsize=ysize*bmi%bmiHeader%biWidth/bmi%bmiHeader%biHeight
endif
xoffset=(rect%right-xsize)/2
yoffset=(rect%bottom-ysize)/2
Last_Error = StretchBlt(hDCPrintDLG,Xoffset,Yoffset,xsize,ysize,hbmComp,&
0,0,bmi%bmiHeader%biWidth,bmi%bmiHeader%biHeight,SRCCOPY)
Last_Error=ENDPAGE(hDCPrintDLG)
Last_Error=ENDDOC(hDCPrintDLG)
Last_Error=DeleteDC(hDCPrintDLG)
Last_Error=DeleteDC(hdcComp)
Last_Error=DeleteObject(hbmComp)
900 continue
endsubroutine PrintDIBbitmap
Jugoslav_Dujic
Valued Contributor II
Can't say why this looong code doesn't work -- only that it's unnecessarily complicated. It should be as simple as:
!Calculate offsets & scaling here
Last_Error = StretchBlt(hDCPrintDLG,Xoffset,Yoffset,xsize,ysize,hdcbitmap,&
0,0,someWidth,someHeight,SRCCOPY)
Jugoslav
myron_r
Jugoslav
Thank you for your help. My code started off as simple as you suggested but it didn't work. I found a couple help documents, "Printing a Document", "Using Bitmaps", and "Device-Inpendent Bitmaps". I also had a C program from OpenGL SuperBible. According to "Printing a Document" you need to initialize the members of a DOCINFO structure so that you can use the StartDoc and StartPage function. For the print dialog you need to initialize members of the Print Dialog structure. I thought that it was necessary to make a device independent bitmap. I found myself trying to initialize a bunch of structures about the bitmap. My code kept getting bigger and bigger.
I am not sure why it doesn't work with the couple of lines of code that you suggest. I think the printer needs more information than what it gets from the bitmap handle that you give it in the StretchBlt command. If you are interested I can send you the C code that prints a bitmap. The only reason I am not using the C code is because when I went to Windows 2000 it quit working (memory error). Since all of my programs are Fortran I wanted a subroutine that prints bitmaps in Fortran.
Myron
Jugoslav_Dujic
Umm, "didn't work" is a broad term -- if a paper came out of the printer it has been set up correctly; if it produced garbage or blank paper, that's another kind of problem.
However...
Are you mixing DC handles and bitmap handles or was it a typo? DCs and bitmaps are not the same. StretchBlt expects a DC handle; I assumed hdcBitmap was one, but rereading your code it seems I was wrong ("hdc" prefix confused me). To "convert" a bitmap to a DC you do need to create a DC first and select the bitmap onto it:
hdcBuffer = CreateCompatibleDC(NULL)
iSt = SelectObject(hdcBuffer, hBitmap)
iSt = Last_Error = StretchBlt(hDCPrintDLG,Xoffset,Yoffset,xsize,ysize,hdcBuffer,&
If it still fails, feel free to contact me privately.
Jugoslav
