Dear all,
I think the ifort 16.0.3 (the most recent version I have access to right now), does not handle private procedures correctly. The example below demonstrates the issue. The Base type declares a private type bound procedure. This should not be visible in any sense in the extending type Extended in my opinion. The compiler refuses to compile the code, claiming that 'An overriding binding and its corresponding overridden binding must have the same number of dummy arguments.' But this is contradictory IMO as the procedure in the Base type is private, and should, therefore, not be be visible outside of it. Therefore, it can not be overriden, so that type bound procedures in extending types may have the same name but different calling signature.
Bálint
module basemod
implicit none
private
public :: Base
type :: Base
integer :: id
contains
procedure, private :: dummy
end type Base
contains
subroutine dummy(this, id)
class(Base), intent(inout) :: this
integer, intent(in) :: id
this%id = id
print *, 'Base'
end subroutine dummy
end module basemod
module extmod
use basemod
implicit none
type, extends(Base) :: Extended
contains
end type Extended
contains
subroutine dummy(this)
class(Extended), intent(in) :: this
print *, 'Extended'
end module extmod
Right - this is a bug we JUST fixed, having been clarified by an interpretation to Fortran 2008. I don't yet know when the fix will be included in a product update and will let you know when I find out. Our issue ID is DPD200247485.
- « Previous
- 1
- 2
- Next »
I just had a chat with the development team lead and he is deferring the fix for the issue reported in the original post until the next major version (second half of 2017). The reason is that our test system, with many tests from customers, had a lot of failures from code that assumed such references were valid. We don't want to have to explain to a lot of upset customers that we deliberately broke their code in a minor update, even if we can point to the standard for backing.
Steve,
Re: "the development team lead .. is deferring the fix for the issue .. until the next major version (second half of 2017)". That's most unfortunate, I feel. If Intel Fortran team is fully convinced the fix is COMPREHENSIVE and CORRECT relative to the standard revision (corrigendum in this case), then I think Intel should make it available right away to customers as part of /standard-semantics, or some such 'umbrella' option in the compiler that ensures full compliance with the Fortran standard.
Please note there are customers for whom standard compliance is paramount which also means adapting to revisions and reinterpretations and corrigenda and like. So if the compiler starts rejecting code that was previously accepted that will be just fine with us as long as it is clear the revised compiler is fully compliant with the standard.
We're concerned the intended timeline for the above fix is now more than a year away and who knows, given budgetary constraints on compiler licensing and support renewals, in our situation the fix may end up several years down the round. One can only venture a guess how much code might potentially get developed that will later be realized to be non-conforming with the standard.
FortranFan, I sympathize, really I do. But we also have to be concerned about the reaction of our many commercial customers whom would take great exception to a minor update breaking their code because we started enforcing a restriction in the standard. Most customers assume that minor updates won't intentionally create breaking changes in semantics - they are (somewhat) more forgiving of such changes in new major versions, especially as we have months-long beta tests of the new versions. That we found so many tests, taken from customer code, that broke with this change makes us unwilling to put the change into a minor update.
We will, as usual, have a free beta test of next year's version starting early in the year. You'll be able to try it out then.
FortranFan, I sympathize, really I do. But we also have to be concerned about the reaction of our many commercial customers whom would take great exception to a minor update breaking their code because we started enforcing a restriction in the standard. ..
Steve,
Thanks but it will be nice if the fix were included in the compiler soon (compiler 17, update 1?) but made effective only with some temporary switch (something that Intel has done in the past), say /assume_f08_0052. Then when Intel thinks the time is right, the change can become the default. This way, the other commercial customers are not affected while those wish to remain on the 'bleeding edge' of the standard (like my org) can avail themselves of the change much sooner..
Dear all,
What about variables? Should they be visible in the extension of a type made in a separate module?
Consider the code:
module A_names
implicit none
private
type :: A_t
private
integer :: a
end type A_t
public :: A_t
end module A_names
module two_names
use A_names
implicit none
private
type, extends(A_t) :: B_t
private
integer :: a
end type B_t
public :: B_t
end module two_names
I'm getting this error (also using ifc 18, not shown below):
$ ifort --version
ifort (IFORT) 17.0.1 20161005
Copyright (C) 1985-2016 Intel Corporation. All rights reserved.
$ ifort -c vars.f90
vars.f90(18): error #8205: A component declared in an extended type cannot have the same name as any accessible component of its parent type.
integer :: a
compilation aborted for vars.f90 (code 1)
- « Previous
- 1
- 2
- Next »
