Problem: Looping over a subroutine
Harry_G_
I try to draw samples and calculate something by writing a subroutine.
! main file
program mymain
use mymodule
implicit none
real,dimension(10)::inputdata
real,dimension(:,:),allocatable::popmat
integer :: snr,pnr,i,nsimc
real :: sdot
integer, parameter :: nsim=100
real, dimension(nsim) :: sdotmat
inputdata = (/1,2,3,4,5,6,7,8,9,10/)
allocate(popmat(5,2))
popmat = transpose(reshape(inputdata,(/2,5/)))
snr=3
pnr=size(popmat,1)
do i=1,nsimc
 call resample(snr,pnr,popmat,sdot)
 sdotmat(nsimc) = sdot
end do
deallocate(popmat)
print*, sdotmat
end program mymain
The subroutine for simulation looks like:
module mymodule
contains
subroutine resample(snr,pnr,popmat,sdot)
implicit none
integer, intent(in) :: snr,pnr
real, dimension(pnr,2), intent(in) :: popmat
real, intent(out) :: sdot
real, dimension(snr,2) :: smat
integer :: m,i,l
real :: r
m=0
do while (m < snr)
 do i=1,pnr
  call random_number(r)
  l = int((real(pnr)-i+1)*r)+1
  if (l .GT. (snr-m)) then
   cycle
  end if
  m=m+1
  smat(m,1:2)=popmat(i,1:2)
 end do
end do
sdot = dot_product(smat(:,1),smat(:,2))
end subroutine resample
end module mymodule
If I write a code to draw random samples INSIDE the subroutine, it works properly. But when I loop over the subroutine from the main, it is compiled, but execution produces an error. Would you let me know what problems are in the codes above? Thanks!!
mecej4
With the main program corrected as follows, the program runs with no errors.
program mymain
use mymodule
implicit none
real :: sdot
integer, parameter :: nsimc=100
real, dimension(nsimc) :: sdotmat
snr=3
pnr=size(popmat,1)
do i=1,nsimc
 sdotmat(i) = sdot
end do
deallocate(popmat)
print*, sdotmat
end program mymain
mecej4
The variable nsimc is used before its value has been set. On Line-18 of the main program, the subscript should probably be the loop variable i rather than nsimc. Perhaps, you meant "nsimc" and "nsim" to be one and the same.
Harry_G_
@mecej4: Thanks. I fixed the small error for the nsimc.
do nsimc=1,nsim
end do
Now it works. Thanks!
mecej4
program mymain
use mymodule
implicit none
real :: sdot
snr=3
pnr=size(popmat,1)
do i=1,nsimc
 sdotmat(i) = sdot
end do
deallocate(popmat)
print*, sdotmat
end program mymain
