Problem calling Fortran DLL
Cliff
I am trying to call a Fortran DLL from VC++.
The IVF code is something like:
module Types
type errorType
sequence
integer*4Error_Flag
character*512Error_Msg
end type errorType
end module Types
subroutine myRoutine(error)
!dec$attributes dllexport, default, stdcall, decorate, alias: 'myRoutine' :: myRoutine
!dec$attributesreference :: error
use Types
write(error%error_Msg,*) 'Error: in myRoutine'
return
end subroutine myRoutine
The C++ header code is something like
#ifdef __cplusplus
extern "C" {
#endif
struct errorType
unsigned char error_flag;
char error_msg[512];
void __stdcall myRoutine
errorType* error
#ifdef __cplusplus
#endif
The problem I have is that when I callthe FORTRAN routine the error_msg variable is correctly set but returns empty.
Can anyone offer some insight, the actually code is more complicated (additional arguments etc) but I hope I have caught the essence of it.
Thanks for your time
Cliff
anthonyrichards
New Contributor III
In your routine, should you not includea TYPE declaration for your argument ERROR. i.e..
TYPE (ERRORTYPE) ERROR
And what is an 'unsigned character' in your C++ Structure??
