29641 Discussions
Problem calling a dummy callback from Fortran
Adrian_F_1
I have a problem calling a dummy callback from Fortran.
We have a C++ program which calls Fortran code, EQCONTOUR.
It passes a function pointer (FCALL) when calling this subroutine.
The purpose is to provide a callback function that the Fortran can call back in the C++ world to echo progress, etc.
This all works fine and here is the code:
EQCONTOUR uses this module:
      module GUI_OLI
        implicit none
        save
        interface
          integer function GUI_FCALL(TEMP,PRES,IPT,JPT,KERR)
            REAL*8 , intent(in)  :: TEMP, PRES
            INTEGER, intent(in)  :: IPT, JPT
            INTEGER, intent(out) :: KERR
          end function
        end interface
        pointer (p_GUI_FCALL, GUI_FCALL)
      end module GUI_OLI
Here is EQCONTOUR:
      SUBROUTINE EQCONTOUR(FCALL)
      USE GUI_OLI
      IMPLICIT NONE
      INTEGER    :: FCALL
      p_GUI_FCALL = FCALL
      IF(GUI_FCALL(TEMP,PRES,IT,IP,KERR) == 0) THEN
      RETURN
      END
This works fine when EQCONTOUR is called from C++.
The problem comes when I want to test calling EQCONTOUR from Fortran.
Here is my code:
      PROGRAM TEST
      IMPLICIT NONE
      INTEGER, EXTERNAL :: FCALL
      call EQCONTOUR(FCALL)
      END
! dummy FCALL
      integer function FCALL(TEMP,PRES,IPT,JPT,KERR)
        FCALL = 1
        KERR = 0
      end function
When I try to call from Fortran as above, I get an access violation on the
IF(GUI_FCALL(... line.
I'm not sure why.
You've left out some critical lines - such as what I suspect is: POINTER (p_GUI_FCALL, GUI_FCALL) in EQCONTOUR The way you have coded EQCONTOUR, it is expecting an integer by reference containing the address of the callback routine. This isn't consistent with simply passing the routine has you have in your test program. Try this: PROGRAM TEST IMPLICIT NONE INTEGER, EXTERNAL :: FCALL INTEGER :: p_FCALL p_FCALL = LOC(FCALL) ! call EQCONTOUR(p_FCALL) END I will also comment that your code will fail if built as a 64-bit program because you are assuming 32-bit addresses. I'd prefer to see this rewritten using procedure pointers and the C interoperability features, but you could simply change the INTEGER :: FCALL in EQCONTOUR to INTEGER(INT_PTR_KIND()) :: FCALL and similarly the declaration of p_FCALL I added above. The C code would need to make sure it is passing a pointer and not an int.
