29653 Discussions
Problem debugging in VS2008 and using a pipeline in command arguments
pacobraxe
Hi!
I am trying to debug my code using VS2008 in windows XP and compiler Intel fortran 12.0. I want to put
as command argument. Unfortunately, the program does not recognize the pipeline and asks all the data by keyboard.
I have read in this web that I should install the SP1 update of the VS2008 to SP1. I have updated from the update page of Microsoft but I still have the same problem. I have attached the information about updates that VS2008 gives.
Thanks in advance for any idea.
Sincerely,
Paco Braxe
Microsoft Visual Studio 2008
Versin 9.0.21022.8 RTM
Microsoft .NET Framework
Versin 3.5 SP1
Edicin instalada: Professional
Microsoft Visual C++ 2008 91990-270-5477302-60141
Actualizacin para Microsoft Visual Studio 2008 Professional - ESN (KB972221) KB972221
Este actualizacin es para Microsoft Visual Studio 2008 Professional - ESN.
Si ms tarde instala un service pack ms reciente, este actualizacin ser desinstalado automticamente.
Para obtener ms informacin, visite http://support.microsoft.com/kb/972221
Intel Visual Fortran Package ID: w_fcompxe_2011.4.196
Intel Visual Fortran Composer XE 2011 Integration for Microsoft Visual Studio* 2008, 12.0.3471.2008, Copyright (C) 2002-2011 Intel Corporation
* Other names and brands may be claimed as the property of others.
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB944899) KB944899
Este revisin es para Microsoft Visual Studio 2008 Professional - ESN.
Si ms tarde instala un service pack ms reciente, este revisin ser desinstalado automticamente.
Para obtener ms informacin, visite http://support.microsoft.com/kb/944899
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB945282) KB945282
Para obtener ms informacin, visite http://support.microsoft.com/kb/945282
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB946040) KB946040
Para obtener ms informacin, visite http://support.microsoft.com/kb/946040
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB946308) KB946308
Para obtener ms informacin, visite http://support.microsoft.com/kb/946308
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB946344) KB946344
Para obtener ms informacin, visite http://support.microsoft.com/kb/946344
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB946581) KB946581
Para obtener ms informacin, visite http://support.microsoft.com/kb/946581
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB947171) KB947171
Para obtener ms informacin, visite http://support.microsoft.com/kb/947171
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB947173) KB947173
Para obtener ms informacin, visite http://support.microsoft.com/kb/947173
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB947180) KB947180
Para obtener ms informacin, visite http://support.microsoft.com/kb/947180
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB947540) KB947540
Para obtener ms informacin, visite http://support.microsoft.com/kb/947540
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB947789) KB947789
Para obtener ms informacin, visite http://support.microsoft.com/kb/947789
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB948127) KB948127
Para obtener ms informacin, visite http://support.microsoft.com/kb/948127
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB953256) KB953256
Para obtener ms informacin, visite http://support.microsoft.com/kb/953256
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB971091) KB971091
Para obtener ms informacin, visite http://support.microsoft.com/kb/971091
Revisin para Microsoft Visual Studio 2008 Professional - ESN (KB973674) KB973674
Para obtener ms informacin, visite http://support.microsoft.com/kb/973674
jimdempseyatthecove
Assume your program name is "YourProgramName"
Define anenvironment variable
YourProgramName_Input = InputDataFile.txt
When your program starts call:
subroutine RedirectInput()
character(len=256) ::InputDataFile
integer :: len, status
call GET_ENVIRONMENT_VARIABLE('YourProgramName_Input', InputDataFile, len, status, .true.)
if(status .eq. 0) then
write(*,*)'Redirecting input: ', InputDataFile(1:len)
open(5,InputDataFile(1:len))
endif
end subroutine
Note, above code not tested
Jim Dempsey
Arjen_Markus
I am not sure such a pipeline will work in the debugging environment. But what you can
do instead is:
open( 5, file = 'datafile' )
... ordinary processing
Less flexible perhaps, but it ought to solve the problem at hand
Arjen
Visual Studio has a tradition of problems in this area. In VS2005 it didn't work at all. In VS2008, the program gets the input ok but if you are running under the debugger, the output, which is not redirected, fails to appear. And VS2010 crashes when I run the same program (which reads from unit 5 and writes to 6) under the debugger.
This issue is not Fortran-specific - I have seen many complaints from C++ users over the years.
What does seem to work is if you pass a filename as an argument in the Debugger properties and then use GET_COMMAND_ARGUMENT to retrieve the text and open the file.
jimdempseyatthecove
endif
end subroutine
Jim Dempsey
Environment variables are tricky to use in Visual Studio. I think GET_COMMAND_ARGUMENT is a better bet. Something like this:
[fortran]    program Console7
    implicit none
    character(80) input_file
    integer input_file_status
    character(100) line
    call GET_COMMAND_ARGUMENT(1,input_file,status=input_file_status)
    if (input_file_status == 0) then
      open (unit=5,file=input_file,status='old')
    end if
do read (5,'(A)',end=99) line write (6,'(A)') trim(line) end do 99 continue end program Console7[/fortran]
pacobraxe
Thank you all for the replies. I have to say that I am very satisfied with this forum and how fast a good answer is obtained.
Regarding this issue, I use GET_COMMAND_ARGUMENT in all my recent programs, but when I want to reuse an old program, it can be a good idea let the read commands (read*,) unchanged. In this situation, to use a pipeline to debug is very useful.
I am surprised about what Steve Lionel says respect to VS2005. I am pretty sure that the pipeline worked for me! Unfortunately, I do not have that computer now to check it.
Paco
pacobraxe
Just to finish my argument, the way I ask for data file in my new programs is very close to what Steve wrote:
[bash]program prueba
implicit none
character(260) :: datafile
integer :: length, status, iu = 5
real :: data
if (command_argument_count() > 0) then !assuming that first arg. is datafile call get_command_argument(1, datafile, length, status) open(newunit=iu, file=datafile) endif read(iu,*) data print*, data end program[/bash]
This program accepts:
1) data by keyword (exe)
2) data by pipeline (exe < datafile)
3) a datafile being the first argument (exe datafile).
Paco
