29641 Discussions
Problem in documentation for quickwin GETVIEWCOORD
dboggs
The documentation says "translate phusical coordinates or window coordinates to viewport coordinates" OK. There are two variations:
CALL GETVIEWCOORD (x, y, t)
where inputs x, y are physical coordinates and are converted to output t, of type xycoord, which are viewport coordinates (integer(2)). OK
CALL GETVIEWCOORD_W (wx, wy, wt)
where inputs wx, wy are window coordinates and are converted to output wt, of type wxycoord, which are window coordinates (real(8)). !
Yes, that's what it says for the second case, and it makes no sense. What it should say is
CALL GETVIEWCOORD_W (wx, wy, t)
where inputs wx, wy are window coordinates and are converted to output t, of type xycoord, which are viewport coordinates (integer(2)).
It is not helpful to have a function to convert window coordinates into window coordinates!
You're right - the output argument of GETVIEWCOORD_W should be described identically to that of GETVIEWCOORD. I will let our writers know - thanks.
In addition, we'll fix the documentation to indicate that the third argument is named S and not T or WT, as that's how it's declared in IFQWIN.
dboggs
Thanks Steve. But re your second message: since T or WT are user-defined names, it doesn't really matter, right? If you're just looking for consistency, note that these derived-type variables are also used in other routines (GETVIEWCOORD, GETWINDOWCOORD, GETCURRENTPOSITION, MOVETO, maybe others) and they are all described as T or WT in the documentation. So I've been using T or WT in most of my coding wherever I have no reason to change.
It matters because the interfaces in IFQWIN use S as the argument name, so if you used argument keywords with T or WT you'd get an error.  For example:
CALL GETVIEWCOORD (X,Y,T=MYT)
If you aren't using keywords, then it doesn't matter. It is important that the documentation match the interface.
dboggs
OK I can see that it matters if and only if you are using argument keywords. That never occurred to me. So are you going to change the documentation for all of the affected subroutines? A partial list for nomination is: GETVIEWCOORD, GETWINDOWCOORD, GETPHYSCOORD, GETCURRENTPOSITION, GETTEXTPOSITION, MOVETO, SETVIEWORG, POLYBEZIER, POLYBEZIERTO, POLYGON (all of the routines that use type xycoord?)
I'll check those out, and if they need changes we'll make them. Thanks.
Added GETARCINFO to the list.
