29487 Discussions
Problem in installing intel fortran compiler 9.1 for windows (evaluation version)
fs532
I have downloaded the evaluation version of intel fortran compiler for windows (w_fc_c_9.1.037_IA32.exe) after getting the seriel number and license file for manuall installtion.
When I run this .exe file it opens up installtion wizard. After going through the installation ( giving the provided seriel number) I getthe two additional foldernamley
C:Program FilesIntelDownloadIntelFortranCompiler91
C:Program FilesCommon FilesIntelLicenses
Sofar it looks that every thing is fine but what next.
Is product installed successfully and ready to run or still need to do something more.
It will be highly appreciated if some one can help me out
The pre requisite
visual c++ 2005 express edition
Microsoft SQL server 2005
Microsoft platform SDK
You should have seen a "Tools" screen with a number of checkboxes for which components of the products to install, and then when you clicked Next, you would have gone through a series of installs.
Try double-clicking on the setup.exe in that Download folder you mentioned. Pay attention to any error messages. Note that all you'll be able to do is build from the command line. If you continue to have problems, please submit an issue to Intel Premier Support. You get full support for the duration of your evaluation period.
