29643 Discussions
Problem installing XE 2015 - Intel.Misc.Utilities
Kipling__Michael
I have a problem with VS 2010 Win7 when installing w_fcompxe_2015.4.221.  After installation I cannot open any VS dialog.  Instead I get the following error message.
"Could not load file or assembly 'Intel.Misc.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=f4875dd4c8d7762f' or one of its dependencies.  The system cannot find the file specified."
I've tried removing XE 2015 and re-installing, repairing VS and checking to see that I have the latest MS updates.  This did not help.
I finally removed XE 2015 and re-installed XE 2013 with w_fcompxe_2013_sp1.5.239, and that solved the problem.
Mike
Would you please try again with Update 3? I don't recommend installation of Update 4, which doesn't change anything except add latent support for VS2015, unless you really need it. I have seen several reports of installation issues with Update 4. If you do try with Update 4 and it still fails, please zip the log files found in your TEMP directory under a folder whose name starts with "pset", and attach it to a reply here.
Kipling__Michael
I tried update 3, but encountered the same problem.  I've attached the log files.
Mike
Thanks - I'll send these to the install team for their analysis.
I am told that this has been fixed - probably as of the 2016 Update 1 release.
