29657 Discussions
Problem installing downloaded evaluation version
wswain10
I've tried twice, removed once the installation of Fortran (ifort) for use in windows. I have visual studio 2003 loaded, but the program states it can not find it to load in the add-in. I can't find the release notes that it refers to about this problem. A couple screens later i point to the SDK folder to show it where the visual studio resides as directed.
I open visual studio and there is no Intel Fortran options as indicated in the getting started guide.
Any help would be greatly appreciated.
Bill
DavidWhite
Valued Contributor II
Quoting - wswain10
Bill
Bill,
You may need to wait for expert advice from Steve Lionel. However, in the interim, a couple of suggestions.
1. Do a repair install on VS 2003 - check that C++ component is installed, as this is required.
2. Check that you have the latest SP for VS installed
David
In Visual Studio, please select Help > About. Click the Copy Info button. Reply here and paste the copied info into the reply text so I can see what you have.
