29393 Discussions
Problem to complier fortran code in abaqus user subroutine
uconnlilu
I am a beginner for fortran and abaqus. I have a very simple USDFLD subroutine for abaqus as follow
SUBROUTINE USDFLD(FIELD,STATEV,PNEWDT,DIRECT,T,CELENT,
1 TIME,DTIME,CMNAME,ORNAME,NFIELD,NSTATV,NOEL,NPT,LAYER,
2 KSPT,KSTEP,KINC,NDI,NSHR,COORD,JMAC,JMATYP,MATLAYO,LACCFLA)
C
INCLUDE 'ABA_PARAM.INC'
C
CHARACTER*80 CMNAME,ORNAME
CHARACTER*3 FLGRAY(15)
DIMENSION FIELD(NFIELD),STATEV(NSTATV),DIRECT(3,3),
1 T(3,3),TIME(2)
DIMENSION ARRAY(15),JARRAY(15),JMAC(*),JMATYP(*),COORD(*)
Y=COORD(2)
FIELD(1) = Y
STATEV(1) = 24.D10+6.D10*FILED(1)
RETURN
END
However, when I run it in abaqus, it gives me the following error
udfld.for(8): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: * <IDENTIFIER>
udfld.for(9): error #5082: Syntax error, found ',' when expecting one of: ( : % [ . = =>
udfld.for(9): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: :: ( : * <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT> ...
udfld.for(10): error #5276: Unbalanced parentheses
udfld.for(10): error #5082: Syntax error, found ',' when expecting one of: ( : % [ . = =>
udfld.for(10): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( % . = =>
udfld.for(16): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: <IDENTIFIER>
udfld.for(17): error #5082: Syntax error, found ',' when expecting one of: ( % . = =>
1 T(3,3),TIME(2)
udfld.for(17): error #6072: A dummy argument of a statement function must be a scalar identifier. [3]
1 T(3,3),TIME(2)
1 T(3,3),TIME(2)
udfld.for(22): error #6353: A RETURN statement is invalid in the main program.
RETURN
udfld.for(16): error #6591: An automatic object is invalid in a main program. [FIELD]
udfld.for(16): error #6591: An automatic object is invalid in a main program. [STATEV]
udfld.for(16): error #6219: This variable, used in a specification expression, must be a dummy argument, a COMMON block object, or an object accessible through host or use association. [NFIELD]
udfld.for(16): error #6219: This variable, used in a specification expression, must be a dummy argument, a COMMON block object, or an object accessible through host or use association. [NSTATV]
udfld.for(18): error #6221: The assumed-size array must be a dummy argument. [COORD]
udfld.for(18): error #6221: The assumed-size array must be a dummy argument. [JMAC]
udfld.for(18): error #6221: The assumed-size array must be a dummy argument. [JMATYP]
udfld.for(17): remark #7713: This statement function has not been used. [T]
1 T(3,3),TIME(2)
compilation aborted for udfld.for (code 1)
Abaqus Error: Problem during compilation - udfld.for
Abaqus/Analysis exited with errors
Anyone could help me?
mecej4
I think that the Abaqus script that you use to build the DLL expects the Fortran source to be in fixed format. In this format, statements start in column 7, continuation marks in column 6, etc. By convention, a file suffix of "for" is used for fixed format source files. Compare the corrected version below with what you posted. Note that the first non-blank characters in lines 1,2 and 4 are in columns 7, 6 and 1.
When you post source code, instead of typing it in the body of your text, use the "insert code" button </> .
C
C
     1 T(3,3),TIME(2)
      Y=COORD(2)
      FIELD(1) = Y
      RETURN
      END
uconnlilu
Thank you so much. The problem already solved with your kindly help.
Have a nice day !
