29396 Discussions
Problem using polymorphism in fortran 2003
wolfpackNC
Hi I don't know if I am doing something wrong or if it's the compiler. I am trying to create a generic linked list implementation. The generic record type will be extended, i.e. store different data and sort on different variables. The extended record types will inherit the sorting and link_insert / link remove method from the parent class. I have tried to boil this down to a simple example. 2 mod files and a driver. The error I get at compile time is
ifort -O -c ll_mod.f90
ifort -O -c ll2_mod.f90
ifort -O -c driver.f90
driver.f90(14): error #6633: The type of the actual argument differs from the type of the dummy argument. [NEWITEM]
call printPriority(newItem)
driver.f90(14): error #6691: A pointer dummy argument may only be argument associated with a pointer. [NEWITEM]
driver.f90(7): error #8223: An entity declared with the CLASS keyword shall be a dummy argument or have the ALLOCATABLE or POINTER attribute. [NEWITEM]
class(recordx), target :: newItem
compilation aborted for driver.f90 (code 1)
make: *** [driver.o] Error 1
here is the code :
[fortran]module ll_mod
   implicit none
    public :: printPriority
   type :: record_generic
      class ( record_generic ), pointer :: previous => null()
      class ( record_generic ), pointer :: next => null()
      integer,public :: p = 0
      contains
        procedure,public :: priority => priority_generic
   end type record_generic
    contains
    function priority_generic(this) result(i)
        class(record_generic) :: this
        integer :: i
        i=this%p
    end function priority_generic
   subroutine printPriority(item)
        class(record_generic), pointer :: item
        write(*,*)item%priority()
   end subroutine printPriority
end module ll_mod
module ll2_mod
use ll_mod
implicit none
   type, extends(record_generic) :: recordx
      real,public :: x = 1234.5678
      contains
        procedure,public :: priority => priorityx
   end type recordx
    contains
    function priorityx(this) result(p)
        class(recordx)  :: this
        real :: p
        p=this%x
    end function priorityx
end module
program driver
use ll2_mod
class(recordx), pointer :: linked_list => null()
class(recordx), pointer :: newItem => null()
allocate(linked_list)
allocate(newItem)
deallocate(linked_list,newItem)
end program driver
[/fortran]
reinhold-bader
New Contributor II
I see two problems with your code: The first one indeed is the error #6633 pointed out by the compiler. The reason for this is that your dummy argument has the POINTER attribute. In this case the actual argument must have the same declared type as the dummy. The reason for this is that it would otherwise be possible to dynamically change the type of the entity inside your procedure to something not type compatible with the actual argument. You can fix this in your client code by declaring
class(record_generic), pointer :: newItem => null()
and performing typed allocation
allocate(recordx :: newItem)
The second problem is that your overriding TBP priorityx does not have the same interface (excepting the passed argument dummy) as the overridden one; the function value must be an integer. So you probably will need to redesign this functionality altogether (the present ifort release might not support all F2003 stuff you need).
Reinhold
