29430 Discussions
Problem with DO WHILE and /names:as_is
Roenningen__Petter
I've encountered a possible bug or issue, which was not a problem in an earlier ifort version (11.1.067), but has surfaced after a software upgrade.
I've been able to reduce the problem to the following, from a rather large and complex software package:
filename: test.for
subroutine test()
do while (.true.)
end do
end subroutine
Compiling this with
ifort test.for /names:as_is
produces the error
test.for(3): error #5082: Syntax error, found '(' when expecting one of: =
do while (.true.)
This does not occur when using /names:lowercase or /names:uppercase.
Is this a known bug or issue, or am I overlooking something vital with regards to FORTRAN here?
This is indeed a bug, though you're doing something I strongly recommend against. At first, I thought the issue was that you spelled the constant wrong and it should be .TRUE. But that doesn't work either. This issue with DO WHILE has already been reported, the issue is DPD200156830. The workaround is to write:
DO WHILE (.TRUE.)
That said, you are writing in some language other than Fortran when you use /names:as_is. There are better solutions to whatever problem you tried to solve with that option. Usually that would be an interface block for the non-Fortran routine with either BIND(C,NAME=) or a !DEC$ ATTRIBUTES ALIAS.
DO WHILE (.TRUE.)
This has been fixed for a future release.
Roenningen__Petter
Thank you for the reply, Steve. It was most helpful.
Petter
