29391 Discussions
Problem with GDB: "Cannot access memory at address 0x0"
spakintel
Hi everybody,
I've got a problem with debugging any fortran program compiled by ifort. Let's suppose we have compiled the following program by ifort -g sample.f
!sample.f
integer ff, gg
dimension:: ff(100), gg(100)
character*3 a
ff=1
gg=2
a="YES"
end
Now if I debug the code using gdb, and try to get the values of local variables defined by program, I see the following outputs:
(gdb) info locals
a = '\001\000\000'
ff = Cannot access memory at address 0x0
As you can see, the debugger has not been able to return the value of "ff". I guess "Cannot access memory at address 0x0" means that the variable is NULL, but I have already defined the "ff" array in the program. I would be grateful if somebody could help me out to get rid of this message.
P.S. My system is Mac (10.5.5) with ifort 10.1.017 andgdb 6.3.50
