I have the Intel Fortran 2025.3 installed with VS 2022 v17.14.21. When I attempt to look at the properties for a Fortran project I am present with the following empty page:
I have tried repairing my install and the problem persist. Any suggestions on how to get the properties to appear.
It seems you didn't select any valid Fortran project.
The project name should appear to the left of the window title, which is not the case for you.
For instance:
Can you explain how you created your project?
I fixed this issue back in December, but have forgotten what I did and it cropped up again.
I do not understand "valid Fortran project." You are correct in that the project name does not appear in the window title, but it compiles so the compiler thinks it is valid. Not sure what I need to change for the properties page to recognize it as valid.
Any insight would be greatly appreciated.
I've never encountered this problem. Do you see the Solution and your project(s) in the Solution Explorer?
