Problem with OPENMP
qlsn5
I am a beginner of using OPENMP in intel fortran 90/95 program.
The following parallel routine gives "forrtl: severe (157): Program exception - access violation"
    ! calculate the additional normal modes
    !$omp parallel
    !$omp do
    do i = 1, tn_subst
        print *, PHI(i).lambda( 1 : 4 )
    end do
    !$omp end do
    !$omp end parallel
where, PHI(:) is a derived data which is allocated and PHI(:).lambda(:) is also allocated variable.
The size of "PHI(:).lambda" is of course exceeds 4.
I look forward to getting your precious comments.
Thank you.
Andrew_Smith
Valued Contributor I
Your part code gives insufficient information given about the total code. Please submit a total source code to replicate the problem.
jimdempseyatthecove
Verify assumptions:
!$omp parallel
!$omp do
do i = 1, tn_subst
  if(allocated(PHI(i)) then
    if(allocated(PHI(i).lambda) then
    else
      print *,'PHI(',i,').lambda not allocated'
    endif
  else
    print *,'PHI(',i,') not allocated'
  endif
end do
!$omp end do
!$omp end parallel
Jim Dempsey
jimdempseyatthecove
Also,
How is PHI made visible to your code?
In particular: is it as a DUMMY? If so, what is the declaration?
Jim Dempsey
qlsn5
PHI is a derived data type.
It is declared like:
type :: modefull_type
    integer(i4b) :: nev   ! number of modes
    integer(i4b), allocatable :: connr_eqn(:)    ! connectivity from local row
                                                ! eqn to global eqn
    integer(i4b), allocatable :: connc_eqn(:)    ! connectivity from local column
                                                ! eqn to generalized coefficient
                                                ! eqn
    real(kp), allocatable :: lambda(:)    ! eigenvalues
    real(kp), allocatable :: aa(:,:)
end type
allocate( PHI(0:tn_subst) )
do i = 1, tn_subst
    allocate( PHI(i).lambda( nev1(i) ) )
end do
Of course, nev1(:) is greater than 4.
After compiling and executing your code, I got the same error:
3.29670329670329        1.15384615384615        1.15384615384615
   1.15384615384615
  0.671962571596566       0.249678894356279       6.850377764331367E-002
  5.216858879043861E-002
shell returned -1073740940
Hit any key to close this window...
qlsn5
jimdempseyatthecove wrote:
Verify assumptions:
!$omp parallel
!$omp do
do i = 1, tn_subst
    else
    endif
  else
  endif
end do
!$omp end do
!$omp end parallel
Jim Dempsey
I tried, but I got the components of PHI(i).lambda(1:4) and "error with shell return -~~".
qlsn5
Also,
Jim Dempsey
PHI is a derived data type which is defined and allocated as:
                                                ! eqn to global eqn
                                                ! eqn
end type
type(modefull_type), allocatable :: PHI(:)
where the components of nev1(:) are greater than 4.
jimdempseyatthecove
What you listed above is what you assume you know is happening in the program and further what you assume you know is passed on to further assumptions.
The question I have is:
Did you put the asserts (test) in and run a test?
My guess is no.
In your latest code outline you have:
In your first post you had:
do i = 1, tn_subst
end do
Now, for me, I see an indicator for a potential error with assumptions. This potential error would have been caught (if present) to some extent my the assert (test) I recommended. Still don't see the potential for error?
The allocation of PHI is zero based indexing, nothing inherently wrong with this... as long as the rest of your code is written with this zero-based indexing in mind. The first post code used 1 based indexing (default for Fortran) as indicated by your do i=1, tn_subst.
Had the part of the code that allocates the .lambda use 1 based indexing for the PHI(i) index, then PHI(0).lambda would not be allocated. The tests I suggested would expose this (though you would have to figure out why).
Also, "print *, PHI(i).lambda(1:4)" assumes the earlier allocation was issued, and that the nev1(i) used for the allocation was not 0, and was of a size .ge. 4. Had 0 been contained in nev1(i), then no allocation been made as size is 0.
Jim Dempsey
