Problem with OPTIONAL
dajum
Can anyone tell me why the PRESENT function is returning TRUE for this even though there is no argument for the last 3 OPTIONAL arguments? I'm using 11.1.065, but seems the same in 12.1 as well.
Program test
integer m,nl(3)
Character*256 fname,modnam,arg2
arg2=' something'
modnam = 'all'
fname = 'test.me'
m = 1
nl(1)=2
call fluidic(m,arg2,fname,nl,modnam)
stop
end
SUBROUTINE FLUIDIC(MREC,NF,F1,N1,MODNAMIN,
x F2,N2,MODNAMIN2)
C
OPTIONAL F2
OPTIONAL N2
OPTIONAL MODNAMIN2
Character*32 F1(1),MODNAM,F2(1),MODNAM2
Character*(*) NF,MODNAMIN,MODNAMIN2
INTEGER N1(1),N2(1),MREC
LOGICAL DOPATHS
C
C
MODNAM = MODNAMIN(1:min(32,(3)))
DOPATHS = PRESENT(MODNAMIN2)
write(*,*)' the logical ',dopaths
IF( PRESENT(MODNAMIN2) ) THEN
MODNAM2 = MODNAMIN2(1:min(32,(3)))
DOPATHS = .TRUE.
ELSE
DOPATHS = .FALSE.
ENDIF
return
end
Dave
lklawrie
I get false.
(after modifying it a bit for free format f90)
dajum
I used a test.for file so I have fixed formating. I get TRUE. Every time. Maybe I will see if the formating makes a difference for me. Formatting didin't make a difference. f90 input still gets true.
lklawrie
if it makes a difference i was using v12.
attached here. added pause so that i could see results from inside the ide.
Anonymous66
Valued Contributor I
I am getting false as well. I tried it with both 11.1.064 and 12.1 update 8.
What compiler flags are you using?
Annalee
Intel Developer Support
dajum
No flags. just "ifort test.f90" or "test.for" for the fixed source version. Both give F and crash for me.
Dave
dajum
c:\V55IVF64\sinda33\models>ifort test.f90
Intel Visual Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100414 Package ID: w_cprof_p_11.1.065
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
Microsoft Incremental Linker Version 9.00.30729.01
Copyright (C) Microsoft Corporation. All rights reserved.
-out:test.exe
-subsystem:console
test.obj
c:\V55IVF64\sinda33\models>test
the logical T
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
test.exe 000000014003D7A3 Unknown Unknown Unknown
test.exe 0000000140001D4B Unknown Unknown Unknown
test.exe 0000000140001154 Unknown Unknown Unknown
test.exe 000000014005670C Unknown Unknown Unknown
test.exe 000000014003CDAB Unknown Unknown Unknown
kernel32.dll 000000007725F33D Unknown Unknown Unknown
ntdll.dll 0000000077392CC1 Unknown Unknown Unknown
An explicit interface is required here. Read this.
dajum
Thanks! I missed that in the examples. But now it works fine for me.
Dave
lklawrie
And worked for me because I have it generate interfaces in the debug compile (or it does it by default):
!COMPILER-GENERATED INTERFACE MODULE: Tue Jan 03 13:41:12 2012
MODULE FLUIDIC__genmod
INTERFACE
SUBROUTINE FLUIDIC(MREC,NF,F1,N1,MODNAMIN,F2,N2,MODNAMIN2)
INTEGER(KIND=4) :: MREC
CHARACTER(*) :: NF
CHARACTER(LEN=32) :: F1(1)
INTEGER(KIND=4) :: N1(1)
CHARACTER(*) :: MODNAMIN
CHARACTER(LEN=32) ,OPTIONAL :: F2(1)
INTEGER(KIND=4) ,OPTIONAL :: N2(1)
CHARACTER(*) ,OPTIONAL :: MODNAMIN2
END SUBROUTINE FLUIDIC
END INTERFACE
END MODULE FLUIDIC__genmod
Generated interfaces are not (supposed to be) used as a substitute for a required explicit interface - they are for diagnostic purposes only. However, we have had bugs in the past where the compiler went ahead and used the generated interface to change the code, and it looks like this is another one. I will report it to the developers.
lklawrie
The interface would not be necessary if the subroutine was "contained" in the program. Correct? Then it becomes part of that module?
Correct. If the subroutine were in a module or was contained in the calling program, that would create the explicit interface. My general advice is that if you feel you have to write an INTERFACE block for Fortran code, you're doing it wrong, though I can appreciate that there are circumstances, such as updating old code, where this might be reasonable.
lklawrie
In general, I agree with that statement:
"My general advice is that if you feel you have to write an INTERFACE block for Fortran code, you're doing it wrong, though I can appreciate that there are circumstances, such as updating old code, where this might be reasonable."
I do like the ability to have a generic routine that in actuality spawns to other specific routines based on argument type.
Generic interfaces are fine. It's when you write a specific interface that declares all the arguments, duplicating the declarations in the actuasl routine, where you can make trouble for yourself.
dajum
I'd like to know if there is a better way to do this, but I'm not sure I follow what you are suggesting. This routine is in a library that get called and linked by the users. So the main program and the code calling it can't contain it it. Is there some way besides an interface spec to do this?
The better way is to put the subroutines in a module. Supply the users with the .mod and the .lib. The .mod provides the declarations and makes sure the routines are always called correctly.
The reported problem has been fixed for a release later this year.
