Problem with Visual Fortran
saeedeh
I am trying to debug a code in visual Fortran, but, every time I encounter the error "Intel visual Fortran compiler for 'Win32' not installed".
My OS is Windows Vista 64-bit, and I use Visual studio 2008 integrating with Visual Fortran. Right now, I am using trial version of visual Fortran 11.1.054, to evaluting that if my codes (written in Compac Visual Fortran 6) can be run on it or not. But I even can not debug a simple code.
Please let me know if there is a solution for my problem.
Thanks a lot.
Saeedeh
Saeedeh,
You installed only the Intel 64 compiler, but Visual Studio always defaults projects to the 32-bit configuration. Please download and install the package whose name ends in "novsshell.exe". This contains both the 32-bit and 64-bit compilers. Before you do that, please read the Fortran release notes on how to make sure that your Visual Studio is configured for 64-bit builds.
Once that is installed, if you wish to use the 64-bit compiler, open your project, select Build > Configuration Manager. Under Active Solution Platform select . Verify that the new platform is "x64", click Ok, then Close.
saeedeh
Dear Steve
Thanks a lot. My problem solved. Now I can run my code in Visual Fortran. Thank you again.
