Problem with generic assignment
Dharma
Hello, Can you help me with the error in the follwing code ? Looks like a bug to me. The problem is described after line 116 of the code.
thanks
Reddy
[fortran]module precision_m
  implicit none
  integer,parameter :: WP=kind(1.0D0)
end module precision_m
module matrixUtils_m
  use precision_m
  implicit none
  type Matrix_t
    integer :: m
    integer :: n
    complex(WP), allocatable :: cMat(:,:)
  contains
    procedure :: assigncMatrix_Matrix
    procedure :: assignrMatrix_Matrix
    generic :: assignment(=) => assigncMatrix_Matrix,assignrMatrix_Matrix
  end type Matrix_t
  interface new_Matrix
    module procedure Matrix_Constructor
  end interface new_Matrix
    ! For now all blocks will be of same size
  type :: BlockTriDiagMat_t
    integer :: nb !numBlock ! numblock
    integer :: bs
    !integer,allocatable :: bs(:,:) ! Size [2,nb]
    type(Matrix_t), allocatable :: udiag(:) ! size nb-1
    type(Matrix_t), allocatable :: diag(:)  ! size nb
    type(Matrix_t), allocatable :: ldiag(:) ! size nb-1
  end type BlockTriDiagMat_t
  interface new_BlockTriDiagMatrix
    module procedure BlockTriDiagMatrix_Constructor
  end interface new_BlockTriDiagMatrix
contains
     ! | Matrix Related Routines
  function Matrix_Constructor(m,n,iValue) result(newMatrix)
    integer, intent(in) :: m
    integer, intent(in), optional :: n
    complex(WP), intent(in),optional :: iValue
    type(Matrix_t) :: newMatrix
    newMatrix%m = m
    if(present(n)) then
      newMatrix%n = n
    else
      newMatrix%n = m
    end if
    allocate(newMatrix%cMat(newMatrix%m,newMatrix%n))
    if(present(iValue)) then
      newMatrix%cMat = iValue
    else
      newMatrix%cMat = (0.0_WP, 0.0_WP)
    end if
  end function Matrix_Constructor
  subroutine assigncMatrix_Matrix(this, Mat)
    class(Matrix_t), intent(inout) :: this
    complex(WP), intent(in) :: Mat(:,:)
    print*,'I am assigning complex matrix of size',size(Mat)
    this%m = size(Mat,dim=1)
    this%n = size(Mat,dim=2)
    this%cMat = Mat
  end subroutine assigncMatrix_Matrix
  subroutine assignrMatrix_Matrix(this, Mat)
    real(WP), intent(in) :: Mat(:,:)
    this%cMat = Mat
  end subroutine assignrMatrix_Matrix
     ! | BTDMatrix Related Routines
  function BlockTriDiagMatrix_Constructor(nb,bs,iValue) result(newMatrix)
    integer, intent(in) :: nb
    integer, intent(in) :: bs
    complex(WP), intent(in), optional :: iValue
    type(BlockTriDiagMat_t) :: newMatrix
    complex(WP) :: iValueCopy
    integer :: ic
    newMatrix%nb = nb
    newMatrix%bs = bs
      iValueCopy = iValue
    else
      iValueCopy = (0.0_WP, 0.0_WP)
    end if
    allocate(newMatrix%diag(nb),newMatrix%udiag(nb-1),newMatrix%ldiag(nb-1))
    do ic=1,nb-1
      newMatrix%diag(ic) = new_Matrix(bs,bs,iValueCopy)
      newMatrix%ldiag(ic) = new_Matrix(bs,bs,iValueCopy)
      newMatrix%udiag(ic) = new_Matrix(bs,bs,iValueCopy)
    end do
    newMatrix%diag(nb) = new_Matrix(bs,bs,iValueCopy)
  end function BlockTriDiagMatrix_Constructor
end module matrixUtils_m
program testMatrix
  use matrixUtils_m
  use precision_m
  implicit none
  type(BlockTriDiagMat_t) :: TDM
  integer :: nb=5
  integer :: bs=5
  integer :: ic
  complex(WP), allocatable :: matValue(:,:)
  allocate(matValue(bs,bs))
  matValue = (0.0_WP, 0.0_WP)
  TDM =  new_blocktridiagmatrix(nb,bs)
  ! This line gives error
  print*,'i am here for erro'
  TDM%diag(1) = matValue ! <>
  ! This line doesnot give error
  allocate(diag(nb))
  ! if you enable the follwoing three lines,
  ! the error in LINE ONE disappears
  !do ic=1,nb
  !  diag(ic) = new_matrix(bs,bs)
  !end do
  diag(1) = matValue
  print*,'i am here for no erro'
end program testMatrix
! compile with
! ifort -assume realloc_lhs matrixUtils.F90
! ifort -V
! Intel Fortran Intel 64 Compiler XE for applications running on Intel 64
!, Version 12.1.0.233 Build 20110811
!Copyright (C) 1985-2011 Intel Corporation.  All rights reserved.
!FOR NON-COMMERCIAL USE ONLY
! Error:
!matrixUtils.F90(118): error #6303: The assignment operation or the binary expres
!sion operation is invalid for the data types of the two operands.   [MATVALUE]
!    TDM%diag(1) = matValue ! <>
!matrixUtils.F90(118): error #6366: The shapes of the array expressions do not co
!nform.   [DIAG]
!compilation aborted for matrixUtils.F90 (code 1)
[/fortran]
The left side of the assignment, TDM%diag(1), is a scalar of type Matrix_t. The right side is a two-dimensional COMPLEX array. What did you want this to do? Perhaps you meant to write:
TDM%diag(1)%cMat = matValue
? Unless you have allocated the cMat component, make sure you compile with -standard-semantics
Dharma
I overloaded the assignment using this subroutine.
Also, I compile the code with -assume realloac_lhs.
As I said, the code works well if i enable lines 121 to 125.
I use these derived data types in bigger code and every thing works well but i had insert the fix i mentioned in lines 121 to 125.
[fortran]subroutine assigncMatrix_Matrix(this, Mat)
 this%cMat = Mat
end subroutine assigncMatrix_Matrix[/fortran]
[bash]
[/bash]
Sorry for having overlooked that. I agree that this seems wrong - I will escalate it to development. Issue ID is DPD200177253.
This problem will be fixed in a release later this year.
