29650 Discussions
Problem with multiple string variables returning to EXCEL VBA
jlgilber
I have downloaded V11.1 for evaluation and am having a problem converting a CVF V6.6 DLL routine. The problem seems to be matching the calling arguments. In the CVF version the VBA code defines the string variable followed by the string length and the FORTRAN code just includes the string variable. With V11.1 I seem to have to include both the string variable and the string length. With this, I get all of the correct values in the FORTRAN code and I output those values in my test code. But then EXCEL gets an error when the FORTRAN code does the RETURN.
I could not find a specific answer to this in the list of issues in the forum, so I am hopefull someone can straighten me out.
Below is the Code I have in my VBA module, the code in the FORTRAN test file, and the output data generated when the program is run, followed by the error I get from EXCEL.
* * * * * * * * * * * * EXCEL VBA * * * * * * * * * * * *
Dim LngYearToRun As Long
Private Const LngLength1 As Long = 140
Private Const LngLength2 As Long = 150
Private Const LngLength3 As Long = 160
Dim LngValue As Long
Dim StrUserPath1 As String * 160
Dim StrUserPath2 As String * 160
Dim StrUserPath3 As String * 160
Private Declare Sub DISPATCHDLL Lib "H:\\Visual Studio 2008\\Projects\\Dll1\\Dll1\\Release\\DLL1.dll" (LngYearToRun As Long, ByVal StrUserPath1 As String, LngLength1 As Long, ByVal StrUserPath2 As String, LngLength2 As Long, ByVal StrUserPath3 As String, LngLength3 As Long, LngValue As Long)
Sub DealemDLLSub()
LngYearToRun = 2010
LngValue = 256
StrUserPath1 = "User Path Name 1"
StrUserPath2 = "User Path Name 2"
StrUserPath3 = "User Path Name 3"
Cells(7, 1).Value = "Before Call"
Call DISPATCHDLL(LngYearToRun, StrUserPath1, LngLength1, StrUserPath2, LngLength2, StrUserPath3, LngLength3, LngValue)
Cells(9, 1) = Time
Cells(7, 1).Value = "FINISHED"
End Sub
* * * * * * * * * * * * Program * * * * * * * * * * * *
Subroutine DispatchDLL(YearToRunIN,Path1,n1,Path2,n2,Path3,n3,n4)
INTEGER N
INTEGER N1,N2,N3,N4,N5,N6
INTEGER ArrayPointer
INTEGER YearToRunIN, NumUnitsIN, Length
Character (len=140) Path1
Character (len=150) Path2
Character (len=160) Path3
!dec$ attributes dllexport :: DispatchDLL
!dec$ attributes alias : "DISPATCHDLL" :: DispatchDLL
!dec$ attributes stdcall, REFERENCE :: DispatchDLL
OPEN(UNIT=999,FILE='H:\\INTEL\\INTEL_errorlog.dat',STATUS='REPLACE',ERR=991)
WRITE (999,*) 'Before write'
WRITE (999,*) YearToRunIN
WRITE (999,*) TRIM(Path1)
WRITE (999,*) N1
WRITE (999,*) TRIM(Path2)
WRITE (999,*) N2
WRITE (999,*) TRIM(Path3)
WRITE (999,*) N3
WRITE (999,*) N4
WRITE (999,*) 'After write'
CLOSE (999)
RETURN
991 RETURN
END
* * * * * * * * * * * * INTEL_errorlog.dat * * * * * * * * * * * *
Before write
2010
User Path Name 1
140
User Path Name 2
150
User Path Name 3
160
256
After write
* * * * * * * * * * * * EXCEL ERROR * * * * * * * * * * * *
Microsoft Office Excel has encountered a problem and needs to close. We are sorry for the inconvenience.
When I click on Debug I get
An unhandled win32 exception occurred in EXCEL.EXE[2508]
CVF and IVF have different default conventions for string length passing. If you add MIXED_STR_LEN_ARG to the !DEC$ ATTRIBUTES directive for the routine, that should take care of it.
