Dear all,
I came across a segmentation fault when vectorizing a simple loop. It appears
that the problem occurs when the loop is vectorized and some indices (not directly the
loop index) to access the array accessed during the loop exceed 2^31 (although 64-bit
integers are used to address the array). The vectorization report (intel ifort version 17.0.4 20170411)
gives (among others) the message:
remark #15328: vectorization support: irregularly indexed load was emulated for the variable <a(j1)>, part of index is linear but may overflow
The problem also appears with ifort 17.0.1 20161005.
Everything works fine with ifort 16.0.1 20151021 even though the loop is vectorized.
The original code looks ok since 64-bit integers are used to address the array, which
appears to be large enough. I cannot print the faulty indices during the loop because
this inhibits vectorization. By rewriting the loop slightly differently (accessing A(J1+LDAFS8*(J-1))
in the code below directly and avoiding the line J1=J1+LDAFS8 inside the loop), the problem
disappears (together with the message "part of index is linear but may overflow" in the vectorization
report).
Is this a known issue? Should one rewrite all loops leading to this message with "overflow" in
the vectorization report?
I copy-paste below a piece of code showing the issue.
Thanks in advance for your help,
Jean-Yves
1/ File t.F containing a subroutine and the loop:
SUBROUTINE VECTORIZE_BUG(A, LA, NASS,IEND_BLOCK,J1_ARG,
& RMAX_NOSLAVE)
IMPLICIT NONE
INTEGER(8) :: J1_ARG, LA
DOUBLE PRECISION :: RMAX_NOSLAVE, A(LA)
INTEGER :: NASS, IEND_BLOCK
INTEGER :: LDAFS
INTEGER :: J
INTEGER(8) :: LDAFS8, J1
LDAFS=NASS
LDAFS8=int(LDAFS,8)
J1 = J1_ARG + 1000000000_8
RMAX_NOSLAVE=0.0D0
DO J=1,NASS - IEND_BLOCK
RMAX_NOSLAVE = max(abs(A(J1)),RMAX_NOSLAVE)
J1 = J1 + LDAFS8
ENDDO
END SUBROUTINE VECTORIZE_BUG
2/ Main program:
INTEGER(8) :: J1
INTEGER(8), PARAMETER :: LA = 2500000000_8
DOUBLE PRECISION, DIMENSION(:), ALLOCATABLE :: A
ALLOCATE(A(LA))
J1 = 1022826928_8 ! => KO
c J1 = 1222826928_8 ! => KO
c J1 = 0822826928_8 ! => OK
IEND_BLOCK = 32
NASS = 16203
A(J1+1000000000_8:LA)=0.0D0
CALL VECTORIZE_BUG(A(1), LA, NASS, IEND_BLOCK, J1,
& RMAX_NOSLAVE)
END
3/ Commands used and result (everything ok with Intel 2016 or without vectorization):
% ifort -qopt-report=5 -qopt-report-phase=vec -O -g -traceback tmain.F t.F
% ./a.out
forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source a.out 0000000000402E34 Unknown Unknown Unknown libpthread-2.19.s 00007FE4B5AD58D0 Unknown Unknown Unknown a.out 0000000000402B82 vectorize_bug_ 18 t.F a.out 00000000004029FF MAIN__ 13 tmain.F a.out 00000000004028AE Unknown Unknown Unknown libc-2.19.so 00007FE4B5538B45 __libc_start_main Unknown Unknown a.out 00000000004027A9 Unknown Unknown Unknown
