29657 Discussions
Problem with procedure pointers: matching arguments
Arjen_Markus
I am trying to use procedure pointers to makea program more flexible, but I ran into a
nasty little compiler error. The following program causes the compiler to complain about
the pointer assignment:
error #8178: The procedure pointer and the procedure target must have matching arguments.
If I put the code in the module "implementations" into the module "abstract", the error goes
away.
Any suggestions (besides creating a humongous module)?
Arjen
! chk_abstract.f90 --
! Investigate a problem with abstract interfaces
! and procedure pointers
module implementations
implicit none
abstract interface
subroutine zfunc_evaluation( param_value, zvalue )
real, dimension(:), intent(in) :: param_value
real, intent(out) :: zvalue
end subroutine
end interface
contains
subroutine zfunc( param, zvalue )
zvalue = param(2) - param(1)
end subroutine
end module implementations
module abstract
use implementations
contains
subroutine select( name, implementation )
character(len=*) :: name
procedure(zfunc_evaluation), pointer :: implementation
select case( name )
case ( 'Z' )
implementation => zfunc
case default
write(*,*) 'Unknown implementation: ', trim(name)
stop
end select
end subroutine select
end module
mecej4
Adding the following lines to round out your code into a complete program
[fortran]program tst
use abstract
impl => zfunc
call select('Z', impl)
call select('Any rose ', impl)
end program tst[/fortran]
and compiling, I found that the program runs as expected, using 11.1.069 (Windows) and 11.1.072 (Linux).
Which version of the compiler did you use?
Arjen_Markus
I am using Intel Fortran 11.1.054 (still - my sysadmin is hunting down the newer version for me).
I take it that the problem has been solved then.
Arjen
Wendy_Doerner__Intel
Valued Contributor I
Some relevant fixes we included between these releases and it sounds like it is fixed in 11.1. Let us know if you still see it after upgrading?
Wendy
Attaching or including files in a post
Arjen_Markus
I will do that.
Meanwhile here is another nasty problem:
module computation_data
implicit none
type computation_method
character(len=40) :: name ! Name of the mechanism
procedure(compute_routine), pointer, nopass :: compute ! Pointer to the compute subroutine
end type
abstract interface
subroutine compute_routine( param_value, zfunc, probability )
procedure(compute_routine) :: zfunc
real, intent(in) :: probability
end subroutine
end interface
end module computation_data
The error message I get with 11.1_054 is:
fit_lookup: Line_seq_number 000000000 was not found
forcom: Fatal: There has been an internal compiler error (C000005)
I had to stare very hard at the code to find the problem (you may see it rightaway). When I fix it, all
is fine;)
Arjen
Arjen_Markus
The original problem is solved with 11.1_065. So now I can proceed with this program.
(The nasty problem I reported yesterday still exists though)
Arjen
Arjen,
Thanks for the internal compiler error report. I have reproduced and reported to engineering with number: DPD200159494. I will update this thread when we have a compiler which resolves the error or a workaround for it.
Wendy
Arjen_Markus
You're welcome. Mind you, I am not sure if the code as such is legal (I have my doubts it can be given a consistent interpretation, given the self-reference). It had me puzzled for a long while.
Arjen
Arjen,
Whether or not it is legal code the compiler should never fail (it should give an error message if illegal). I will update this thread with engineerings findings.
Wendy
Arjen_Markus
Hello Wendy,
yes, I know and that is the reason I posted this example. (Robert Corbett from Sun assures me in the c.l.f thread I started on this subject that it is legal. But whether it is useful, I am not sure.) Anyway the main
point is indeed the compiler error, not the code.
Arjen
Arjen,
The 12.0 Update 2 compiler no longer emits an internal compiler error for this test case. Engineering considers it fixed by some changes they made to address other issues.
Wendy
Arjen_Markus
Wendy,
that is good to hear.
Arjen
