29647 Discussions
Problem with -recursive -assume realloc_lhs -standard-semantics
MR
I see different results for the attached code depending on the used compiler flags. Notice that the code uses a recursive elemental subroutine, which I understand is allowed in f2015, but not allowed by the previous standards, hence the compiler flag -recursive .
Apart from -recursive, I think the code should work without depending on other compiler flags.
The expected result is printing -2 10.
$ ifort -recursive ifb.f90 -o ifb
$ ./ifb
[nothing is printed]
$ ifort -recursive -assume realloc_lhs  ifb.f90 -o ifb
$ ./ifb
          -2          10  [the correct result]
$ ifort -recursive -assume realloc_lhs -standard-semantics ifb.f90 -o ifb
$ ./ifb
 1986356271 1937010735  [arbitrary values]
I am using ifort Version 15.0 Build 20150407.
module m1
! Define an abstract type, a container and the corresponding assignment
 implicit none
 type, abstract :: a_abs
 end type a_abs
 type, extends(a_abs) :: t_cnt
  class(a_abs), allocatable :: f
 end type t_cnt
 interface assignment(=)
   module procedure to_cnt
 end interface
contains
 elemental subroutine to_cnt(y,x)
  class(a_abs), intent(in)  :: x
  type(t_cnt), intent(out) :: y
   select type(x)
    type is(t_cnt)
     y = x%f ! equivalent to "call to_cnt( y , x%f )"
    class default
     allocate( y%f , source=x )
   end select
 end subroutine to_cnt
end module m1
module m2
! Define a specific type and an operation
 use m1, only: a_abs
 implicit none
 type, extends(a_abs) :: t_a
  integer, allocatable :: i(:)
 end type t_a
contains
 elemental function add(x,y) result(z)
  class(t_a), intent(in) :: x, y
  type(t_a) :: z
   z%i = x%i + y%i
 end function add
end module m2
program p
 use m1
 use m2
 implicit none
 type(t_a) :: a, b
 type(t_cnt) :: cnt
 allocate( a%i(2) , b%i(2) )
 a%i = (/  0 , 6 /)
 b%i = (/ -2 , 4 /)
 cnt = add( a , b )
 select type( f => cnt%f )
  type is(t_a)
   write(*,*) f%i
  class default
   write(*,*) "class default"
 end select
end program p
The first result is understandable. The last is not, but curiously it reproduces for me only on Linux, not Windows. Very interesting. I found that if you add -assume noprotect_parens, you get the correct result. (This is one of the things that -standard-semantics turns on.) Escalated as DPD200374568.
TimP
With -stand set, ifort 16.0 rejects "recursive elemental subroutine"
-recursive doesn't appear to make a difference.
-Qprotect-parens doesn't pose a problem, although assume:protect_parens does produce run-time failure.
MR
Steve Lionel (Intel) wrote:
The first result is understandable. The last is not [...]
Steve, thank you. Concerning the first result however, I don't see why -assume realloc_lhs should make a difference, since all the allocations should take place in the source allocation.
MR
OK, I assume that whatever choice in terms of extensions is fine; still it would be nice to be able to override some settings of -stand with an additional, more specific option like -recursive ...
You need -assume realloc_lhs (or -standard-semantics which includes it) because your assignment to z%i depends on it.
Eventually we will support the F2015 relaxed restriction on RECURSIVE ELEMENTAL.
MR
Oh, yes, sorry, I added the two allocations in the main program and forgot this one; adding allocate(z%i(size(x%i))) removes the need for realloc_lhs, so the problem here is completely independent from -assume realloc_lhs .
Marco
