29657 Discussions
Problem with registration on second desktop
minomus
Its a problem to activate Visual Fortran Compiler Pro Ed Win Acad, Single User License on second desktop.
Installation on my work desktop was normal: the activation code has been received the unlock code and used. But when trying to install on home desktop there is mistake when entering the license code, the further stages are unavailable. Moreover, after a few times the installer on home desktop even longer run.
What can I do?
TimP
If you're having trouble (temporary or permanent) making the connection to the license verification server, you should be able to copy the license file over and install without connecting to server. If you copy the file into the \common files\intel\licenses\ folder, same as on the working installation, the installer should simply ask whether you want to use the existing license.
