Problem with source ifort in csh
hossein309
I used source command in csh shell as follow:
source /opt/.../ifortvars.csh ia32
but i recive this error:
ERROR: Unkown switch ". Accepted values ia32, intel64, ia64
I am confused beacuse i write "ia32" switch but it request ia32 !!
Anyone can help me ?
Kevin_D_Intel
Showing the complete path to the script would show the version of the compiler used, which might be a key clue.
On Linux, when providing the script a bad value, the error received typically looks like this:
$ source /opt/intel/Compiler/11.0/083/bin/ifortvars.csh ia3
ERROR: Unknown switch 'ia3'. Accepted values: ia32, intel64, ia64
Maybe it can be determined what the script sees in your case for the argument if executed this way (adjust the path accordingly for your compiler version installed):
csh -x /opt/intel/Compiler/11.0/083/bin/ifortvars.csh ia32
