29632 Discussions
Problem with user defined pointer structures and modules
pwlivermore wrote:
Surely (a) defining identical user types in each module and (b) replacing each definition by a USE statement to a separate "definitions module" should be the same?
Well, you may think so, but the Fortran standard considers these distinct types. Your workaround is the correct solution.
