Hi !
I'm using a fortran-lib of a partner (for calculating beams) and integrated the start-function in my C++ code.
In summer 2004 I hade the typical problems of different C-Librarys. We solved this problem by setting /libdir:noauto . My application has to be bild as a Multi-threaded DLL (/MD) or in case of the debug version as Multi-threaded Debug DLL (/MDd). I think my partner compiled the lib always as debug mode
All worked fine for the last 1,5 jears (I got some updated versions). The function used a characterstring as variable to define a path wher input data exists ans outputdata should be stored.
extern "C" void __stdcall TDFLSAKS(const char * path, Tint4 size);
Now our partner had to add same new features in the fortran-lib. And the function has now two variables one defining the existing input-file, and defining the outputfile.
extern "C" void __stdcall TDFLSAKS(const char * Inputfilename, Tint4 size, const char * Outputfilename, Tint4 size);
I have two problems now:
1) I got a version in Releas mode of my partner. Defining the /libdir:noauto setting does not have any results - I get the typical Link errors -
libc.lib(crt0init.obj) : error LNK2005: ___xc_a already defined in msvcrt.lib(cinitexe.obj)
When I check the lib with dumpbin.exe I find defined defaultlibrarys (dfor.lib libc.lib) So it seems to require a application in single-thraed nodebug mode.
Settings in fortran are:
/compile_only /libdir:noauto /nologo /threads /warn:nofileopt /module:"Release/" /object:"Release/"
Do I have to specify the run-time librarys in fortran for the releas mode (although I use the disable default library rules) ????
2) They send me the lib in debug mode with the settings:
/check:bounds /compile_only /debug:full /libdir:noauto /nologo /threads /traceback /warn:argument_checking /warn:nofileopt /module:"Debug/" /object:"Debug/" /pdbfile:"Debug/DF60.PDB"
Now I can compile and link my application, all seems to work fine. When I jump into the fortran-function I get a correct output file (at the defined location) but I never come out of the function - or maybe the function terminates parts of my application. In debug mode (in my C++ application) I only get 22 messages like:
The thread 'Win32 Thread' (0x7c8) has exited with code 0 (0x0).
Can anybody tell me why I didn't fall back into my application from the fortran function ??? Is it a problem of the settings - maybe the Reentrance Support (it is defined as Threaded) ?? My partner could not tell me which options they used for the last working version (Nov. 2005).
/libdir:noauto should do the trick, but it's just possible that he didn't compile properly all source files with it. For example, when I examine my Xeffort library with dumpbin /directives, I don't get any DFOR* dependency. Is it perhaps possible that there's a !DEC$OBJCOMMENT LIB: dfor.lib hanging on (I see those dependencies for my .lib because I spelled out !DEC$OBJCOMMENT)? In any case, you ought to get dumpbin /directives with an emptly list.
As for the debugging problem: it's difficult to tell what's wrong without seeing the actual code. Sometimes you get spurious "The thread 'Win32 Thread' (0x7c8) has exited with code 0 (0x0)." for totally unrelated threads, spawned by e.g. GetOpenFileName or various other shell routines. Check if 0x7C8 is really the identifier of the thread you're debugging (Debug/Threads); does the Fortran code run in an explicitly spawned thread by your code or....?
@Jugoslav: First I want to say thank you. You solved the problem for/with me in summer 2004.
Would it help if they compile the lib by using Rebuild All (maybe first starting a clean) ??
For the whole calculation I start a new thread, but the fortran routine is only part of this and I spawn no new one. Maybe the debugging problem depends on the files I specify as variables??
As for the "dying thread" problem, many CVF RTL routines are known to just "silently die on errors", such as I/O errors without IOSTAT/ERR/END arguments, or math errors. It's difficult to say what is the exact culprit, but offhand I predict a file I/O error. If that's the case, you have to debug it step-by-step or by "bisection method", until you find the line causing the "sudden death". Alternatively, put the IOSTAT/ERR arguments throughout OPEN and READ statements and handle the errors properly-- it's a good practice to detect and properly report such errors instead of leaving the user (or yourself
