29649 Discussions
Problems debugging Intel Fortran 8.1 (patch 1.023) in VS .Net
aoj
Please look at the attatched example, where I am allocating two structures of same type and size. The first parameter is allocated static and the other one dynamic. It isnot possible to evaluate information from thedynamic allocated parameter.
Are there any settings that can solve my problem.
Thanks in advance
Axel Ohrt Johansen
Elsam-Engineering
Jugoslav_Dujic
Valued Contributor II
You forgot the attachment, but never mind -- that bughas beendiscussed thoroughly here, on several occasions. I almost forgot about it -- I thought it was fixed, but apparently it wasn't. I think its current status is "will be fixed in the next release", but I'm not sure. There's no sensible workaround, I'm affraid.
Jugoslav
aoj
I hope you are wrong. Sorry about the attachments, here you have the solution.
But thanks anyway
Axel Ohrt Johansen
