29649 Discussions
Problems with IMSL for Compaq Fortran - Windows XP
rfirmeza
I run Compaq Visual Fortran Professional Edition 6.6.a. for Windows. Recently I tried to set up the library IMSL, but had some problems. I saw that in the professional version, IMSL is included, but it looks like only a few commands are available.
Linear solver (.LIN_SOL_GEN) is available, but sparse (LSLXG) is not.
The errors I get when trying to run an example from the manual with the following commands:
USE LSLXG_INT
USE WRRRN_INT
USE L4LXG_INT
Error: Error in opening the Library module file. [LSLRT_INT]
Did anybody face the same problem?
Thanks for any help,
Rfirmeza
You are looking at a manual for IMSL 6 but what came with CVF Pro is IMSL 5 which does not provide modules such as the xxx_INT modules. There are thousands of routines available, but make sure you read the correct documentation.
