29648 Discussions
Problems with compiling "Hello World"- Program
winstonkl
I'm quite new to Fortran and I'm in trouble.
I hope you can help me out.
I tried to compile and link the following Fortran Program:
program fortrantest
implicit none
print *, 'Hello World'
end program fortrantest
I saved it in ftest.f90 and compiled it with:
ifort ftest.f90.
The result was an Object-file.
Now i tried to link the object-file with the gnu linker "ld" but it didn't worked.
So now my question:
Do I can get it to work that I can link the object-file to an executable program?
If Yes, how? If Not, then why not?
Hope you can help me
winstonkl
Intel Fortran for Windows does not work with the gnu tools. Are you using Windows or Linux?
On Windows, you must first install one of the prerequisite Microsoft development products (for command line only use, the free Visual C++ 2005 Express Edition will do) and then reinstall Intel Fortran.
You would then compile and link together using the:
ifort ftest.f90
line. My guess is that you got an error about it being unable to link and you tried ld instead, which simply won't work.
winstonkl
I'm using Windows and thought I can use the Intel Fortran with the GNU-tools.
I found no real answer on this on the intel website.
But I went wrong.
Anyway, thanks for the answer.
Are there any plans to make the Intel Fortran Compiler work with the GNU-tools under windows?
winstonkl
No plans. The GNU tools use an incompatible format.
As I said, you can get Visual C++ 2005 Express Edition for free, and that works just fine to provide the linker and libraries Intel Fortran needs.
