Problems with constant expressions
MR
consider the following code:
program p
 implicit none
 logical, parameter :: use_v1 = .true.
 integer, parameter :: v1 = 3, v2 = 8
 integer, parameter :: &
  ! this produces a warning at compile time and wrong result
   i = v1*count( (/use_v1/) ) + v2*count( (/.not.use_v1/) )
  ! this produces an ICE at compile time
  !i = v1*count( (/use_v1/) ,kind=kind(i)) + v2*count( (/.not.use_v1/) )
 write(*,*) i
end program p
Compiling with
ifort -stand f08 p.f90 -o p
I see two warnings and wrong results at run time (-3 instead of 3)
$ ifort -stand f08 p.f90 -o p
p.f90(9): warning #6192: Fortran 2008 does not allow this data type conversion.
$ ./p
          -3
Isn't the code right? In any case, I don't understand which type conversion is intended here.
Using the commented line, where the kind is specified, I see an internal compiler error.
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0 Build 20150121
Thanks, Marco
The "wrong result' is a bug we recently fixed. I'll make sure the standards warning and internal compiler error get addressed as well. Thanks. Issue ID is DPD200366418 (the "wrong result" issue is DPD200366183.)
MR
OK, thank you. Marco
These problems have been fixed in our sources - I expect the fix to be included in 15.0 Update 3.
