29376 Discussions
Problems writing/reading unformatted files with Intel fortran and gfortran
Polk__Jay
Hi, I am trying to use a code on both Windows with an Intel compiler and on Mac OS with gfortran 6.5.0 and can't get the gfortran version to read parts of an unformatted file.  I wrote a test code that has the problematic section and verified it works in writing and reading the file on the Intel compiler and on the gfortran compiler. However, if I comment out the write portion and just try to read the file written on the Windows side of the machine (Parallels) with the gfortran version, some of the data is not read properly.  I'm including the test code below and attaching the file.  The "cel(1), f_ei,f_en,f_egyro,f_wall,f_ex,f_wallBC =" data are not read correctly (the data before that are read in properly, however). Is there some incompatibility in unformatted files?
PROGRAM Testo
  IMPLICIT NONE
  INTEGER, PARAMETER :: ncelMAX=6800
  REAL*8  :: dt
  LOGICAL :: MagON,BFmesh
  INTEGER :: nslice_Ver, nslice_verzr, nslice_Edg, nslice_edgzr
  INTEGER :: nFluid, nChrge, nCel, nBCs, nEdg, nVer , nCelzr, nBCszr, nEdgzr, &
       nVerzr, MinSliceCel, MaxSliceCel, MinSliceCelzr, MaxSliceCelzr
  TYPE cell_obj
     INTEGER*4 verNo(4),edgNo(4)
     INTEGER*4 Bln   !BField Mesh
     REAL*8 f_ei,f_en,f_egyro,f_wall,f_ex, f_wallBC
  END TYPE cell_obj
  TYPE(cell_obj) cel(ncelMAX)
  dt = 2.0E-8
  MagON = .TRUE.
  BFmesh = .TRUE.
  nslice_Ver = 1
  nslice_verzr = 2
  nslice_Edg = 3
  nslice_edgzr = 4
  nFluid = 3
  nChrge = 3
  nCel = 3000
  nBCs = 4000
  nEdg = 5000
  nVer = 6000
  nCelzr = 7000
  nBCszr = 8000
  nEdgzr = 9000
  nVerzr = 10000
  MinSliceCel = 100
  MaxSliceCel = 200
  MinSliceCelzr = 300
  MaxSliceCelzr = 400
  cel(1)%verNo(1) = 1
  cel(1)%verNo(2) = 2
  cel(1)%verNo(3) = 3
  cel(1)%verNo(4) = 4
  cel(1)%edgNo(1) = 1
  cel(1)%edgNo(2) = 2
  cel(1)%edgNo(3) = 3
  cel(1)%edgNo(4) = 4
  cel(1)%Bln = 1000
  cel(1)%f_ei = 2.0E6
  cel(1)%f_en = 2.0E7
  cel(1)%f_egyro = 2.0E8
  cel(1)%f_wall = 3.0E6
  cel(1)%f_ex = 3.0E7
  cel(1)%f_wallBC = 3.0E8
  OPEN(UNIT=10,FILE='restartData_TEST',FORM='UNFORMATTED')
  REWIND(10)
  WRITE(10) dt, MagON, nslice_Ver, nslice_Edg, nslice_verzr, nslice_edgzr, BFmesh
  WRITE(10) nFluid, nChrge, nCel, nBCs, nEdg, nVer , nCelzr, nBCszr, nEdgzr, nVerzr, MinSliceCel, MaxSliceCel,MinSliceCelzr,MaxSliceCelzr
  WRITE(10) cel
  CLOSE(10)
  REWIND(10)
  READ(10) dt,MagON,nslice_Ver,nslice_Edg, nslice_verzr, nslice_edgzr, BFmesh
  PRINT *, "First line = ", dt,MagON,nslice_Ver,nslice_Edg, nslice_verzr, nslice_edgzr, BFmesh
  READ(10) nFluid, nChrge, nCel, nBCs, nEdg, nVer , nCelzr, nBCszr, nEdgzr, nVerzr, MinSliceCel, MaxSliceCel,MinSliceCelzr,MaxSliceCelzr
  PRINT *, "Second line = ", nFluid, nChrge, nCel, nBCs, nEdg, nVer , nCelzr, nBCszr, nEdgzr, nVerzr, MinSliceCel, MaxSliceCel,MinSliceCelzr,MaxSliceCelzr
  READ(10) cel
  PRINT *, "cel(1), verNo(4),edgNo(4) = ",cel(1)%verNo(1),cel(1)%verNo(2),cel(1)%verNo(3),cel(1)%verNo(4),cel(1)%edgNo(1),cel(1)%edgNo(2),cel(1)%edgNo(3),cel(1)%edgNo(4)
  PRINT *, "cel(1), Bln = ",cel(1)%Bln
  PRINT *, "cel(1), f_ei,f_en,f_egyro,f_wall,f_ex,f_wallBC = ",cel(1)%f_ei,cel(1)%f_en,cel(1)%f_egyro,cel(1)%f_wall,cel(1)%f_ex,cel(1)%f_wallBC
  PAUSE 'DONE'
END PROGRAM Testo
John_Campbell
New Contributor II
There is no guarantee both programs will have the same storage order for writing cell.
You could try replacing "WRITE(10) cel" by :
  WRITE(10) cel%verNo
  WRITE(10) cel%edgNo
  WRITE(10) cel%Bln
  WRITE(10) cel%f_ei
  WRITE(10) cel%f_en
  WRITE(10) cel%f_egyro
  WRITE(10) cel%f_wall
  WRITE(10) cel%f_ex
  WRITE(10) cel%f_wallBC
A simpler change that may address possible storage order issues between gFortran and iFort could be:
  TYPE cell_obj
    SEQUENCE
     INTEGER*4 Bln, BField   ! Mesh
  END TYPE cell_obj
This changes each type record to a multiple of 8 bytes, but I'd expect the first change to work.
John_Campbell
New Contributor II
Unformatted binary files use a record size header and trailer, which can be different between different compilers or versions.
You may want to review the gFortran option "-frecord-marker=length". Changing this value to =4 may help, although this would still require a similar convention for the header and trailer formats between gFortran and ifort.
Alternatively, unformatted direct access binary files with fixed length records do not have a header or trailer and are easier to share between Fortran programs compiled with different compilers. These have limited flexibility if records are not simple array dumps of the same size. I am familiar with this being a viable solution.
However, depending on the operating system that is being used, there may still be an "endian" byte order issue for binary numbers that are stored. This can also be addressed via the gFortran option "-fconvert=conversion", or resort to an integer*1 byte(4 or 8) reordering solution.
I am sure ifort provides similar options if required.
Polk__Jay
Hi John,
thanks for the quick response.  I tried "-frecord-marker=4" and "-fconvert=little-endian" and neither fixed the problem. By trial and error I was able to get it to work if the variables in the structure under the TYPE declaration are grouped by INTEGER, REAL, and LOGICAL (which I added).  The order doesn't seem to matter, but if I mix them, like the original code, it does not work.  Could that be an extra constraint from gfortran?
mecej4
You have some source lines that are over 132 characters long. Those lines happen to contain the I/O lists of unformatted file I/O statements, and a Fortran compiler may truncate those lines to 132-character lines. Use compiler options that allow source lines longer than 132 characters to be compiled, or edit the source file and break up the long lines.
Unformatted files on Windows, Linux and OSX, produced by programs compiled with Intel Fortran and Gfortran, are compatible with one or two exceptions: RECL= clauses in file OPEN statements, which your example does not use. The binary representations of .TRUE. and .FALSE. may differ from one Fortran compiler and another. I/O list values obtained from floating point calculations are subject to precision loss.
Steve_Lionel
As mecej4 says, ifort and gfortran use the same on-disk layout for unformatted files, even those with records longer than 1GB. You are using a quite old gfortran version, but it should still work.
I don't see that you attached the data file in question, nor did you provide details about what didn't "read properly" and how it was wrong.
Polk__Jay
I'm attaching two data files--one stored with the code on Windows with ifortran (VS2010) and the other stored on the Mac with gfortran. The code on the Mac reads the Mac file properly, but when it reads the Windows file the reals f_ei,f_en,f_egyro,f_wall,f_ex, f_wallBC are not correct (all read as 0 or xxxe-315).  I'm in the process of trying to convert the file storage to HDF5, but it's a lot of work. If there's an easier solution, that would be great!
Steve_Lionel
The layouts of these files are the same. One difference I can see relates to the LOGICAL values, as the default representations of true are different, but this should have no practical effect.
These files were not written by the code you show in the first post. Please show the code you used on both systems.
The second record is completely wrong in both.
Polk__Jay
The code is essentially the same--looks like I changed the order of the some items that are written and read.  I only assign values to the first element of the cel array, so that may be why the second record looks wrong.  I'm attaching both codes.  Thanks!
John_Campbell
New Contributor II
  WRITE(10) cel%verNo
  WRITE(10) cel%edgNo
  WRITE(10) cel%Bln
  WRITE(10) cel%f_ei
  WRITE(10) cel%f_en
  WRITE(10) cel%f_ex
  TYPE cell_obj
    SEQUENCE
  END TYPE cell_obj
Steve_Lionel
You sure did rearrange the writes - no wonder I was confused.
As John suggests, the two compilers differ in how or whether they pad misaligned components in a derived type. In addition to reordering the components so that all are naturally aligned, you could probably get it to work by giving the type the BIND(C) attribute. This will make both compilers order and pad the same way their "companion C processor" would, and I am pretty sure gcc and MSVC do this the same way. But reordering would be my preference, as that eliminates a possible variable.
Polk__Jay
Thank you both for the quick responses!  Both approaches (writing individual components or adding SEQUENCE) appear to work in my test code.  I will add the SEQUENCE keyword to the structures in the big code and see if that solves the problem. If so, then you have spared me a lot of work rewriting the code to store in HDF5 format!
Steve_Lionel
SEQUENCE is not guaranteed to eliminate the problem, but if it works for you, fine. Just be aware that it isn't a perfect solution.
Polk__Jay
Yes, I think i have to go with reading each component of the derived type anyway. Even if SEQUENCE worked, I couldn't read older restart files.
