Procedure component
abhimodak
Hi
I am trying procedure component with version 11.0.039 beta to fake a type bound procedure (at least I think that is what I am doing :) )
But I get compilation error as:
For Test # 1 (see below for source code)
Error 1 error #6460: This is not a field name that is defined in the encompassing structure. [SHOW]
Error 2 Compilation Aborted (code 1)
The output log is
Compiling with Intel Fortran 11.0.039 [IA-32]... ifort /nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug\" /object:"Debug\" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc8 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 8\VC\bin" "C:\Abhi\MySource\Tests\Test_TypewithPointers\NewMain.f90" C:\Abhi\MySource\Tests\Test_TypewithPointers\NewMain.f90(288): error #6460: This is not a field name that is defined in the encompassing structure. [SHOW] Call Trial%Show(Trial, j) --------------------^ fortcom: Fatal: There has been an internal compiler error (C0000005). compilation aborted for C:\Abhi\MySource\Tests\Test_TypewithPointers\NewMain.f90 (code 1) Test_TypewithPointers - 2 error(s), 0 warning(s)
And for Test # 2
Error 1 Compilation Aborted (code 1)
The output log is
Deleting intermediate files and output files for project 'Test_TypewithPointers', configuration 'Debug|Win32'.
Test_TypewithPointers - 1 error(s), 0 warning(s)
I am not sure what I am doing wrong. Below is the source code for two methods I tried.
Abhi
[1] Test # 1
Module TypeWithProcedure
Implicit None
Type Mytype
Integer :: n
Procedure(), Pointer, NoPass :: Show
End Type Mytype
Contains
Subroutine Display(DummyType, iSomeThingElse)
Implicit None
Type(Mytype), Intent(INOUT) :: DummyType
Integer, Intent(OUT) :: iSomeThingElse
Write(*,*) DummyType%n
iSomeThingElse = 1
End Subroutine Display
Subroutine Initialize_Mytype(DummyType)
Implicit None
Type(Mytype), Intent(OUT) :: DummyType
DummyType%n = 0
DummyType%Show => Display
End Subroutine Initialize_mytype
End Module TypeWithProcedure
Program Test_TypeWithProcedure
Use TypeWithProcedure
Implicit None
Integer :: j
Type(Mytype) :: Trial
Call Initialize_Mytype(Trial)
j = 0
Print *, j
End Program Test_TypeWithProcedure
[2] Test # 2
Module TypeDefinition
Implicit None
Type Mytype
Integer :: n
End Type Mytype
End Module TypeDefinition
Module TypeProcedures
Use TypeDefinition
Implicit None
Contains
Implicit None
iSomeThingElse = 1
End Module TypeProcedures
Module TypeBind
Use TypeDefinition
Use TypeProcedures
Implicit None
Implicit None
DummyType%n = 0
End Module TypeBind
Use TypeDefinition
Use TypeBind
Implicit None
Integer :: j
j = 0
Print *, j
Kevin_D_Intel
The 11.0 Beta compiler is suffering an internal compiler error for both cases and while we ask that customer file Premier issues against the Beta compiler, I will do that for this instance.
I may be wrong, but I think the PROCEDURE statement may require a name of an abstract interface or a procedure with an explicit interface.
Perhaps the changes I made below to declare and use ShowMe will accomplish what you are after.
[cpp]  1 Module TypeWithProcedure
  2 Implicit None
  3
  4 Type Mytype
  5 Integer :: n
  6 Procedure(ShowMe), Pointer, NoPass :: Show
  7 End Type Mytype
  8
  9 Abstract Interface
 10   Subroutine ShowMe(DType,iThing)
 11     Import Mytype
 12     Type(Mytype), Intent(INOUT)  :: DType
 13     Integer,      Intent(OUT)    :: iThing
 14   end subroutine ShowMe
 15 end interface
 16
 17 Contains
 18
 19    Subroutine Display(DummyType, iSomeThingElse)
 20    Implicit None
 21
 22    Type(Mytype), Intent(INOUT)  :: DummyType
 23    Integer,      Intent(OUT)    :: iSomeThingElse
 24
 25    Write(*,*) DummyType%n
 26
 27    iSomeThingElse = 1
 28
 29    End Subroutine Display
 30
 31    Subroutine Initialize_Mytype(DummyType)
 32    Implicit None
 33
 34    Type(Mytype), Intent(OUT) :: DummyType
 35
 36    DummyType%n = 0
 37    DummyType%Show => Display
 38
 39    End Subroutine Initialize_mytype
 40 End Module TypeWithProcedure
 41
 42 Program Test_TypeWithProcedure
 43
 44 Use TypeWithProcedure
 45 Implicit None
 46
 47 Integer :: j
 48 Type(Mytype) :: Trial
 49
 50 Call Initialize_Mytype(Trial)
 51
 52 j = 0
 53 Call Trial%Show(Trial, j)
 54 Print *, j
 55
 56 End Program Test_TypeWithProcedure[/cpp]
Kevin_D_Intel
  2 Implicit None
  3
  4 Type Mytype
  5 Integer :: n
  7 End Type Mytype
  8
 11     Import Mytype
 15 end interface
 16
 17 Contains
 18
 20    Implicit None
 21
 24
 26
 28
 30
 32    Implicit None
 33
 35
 36    DummyType%n = 0
 38
 41
 43
 45 Implicit None
 46
 47 Integer :: j
 49
 51
 52 j = 0
 54 Print *, j
 55
abhimodak
Hello Kevin
Many thanks for your response and taking care of submitting it to the premier support. Your snippet works as expected.
There are two points in my mind:
(1) The procedure pointer component is surely NOT required to have the interface given. The only restriction for the implicit interface is that the prcedure has to be "NoPass". While for the purposes of "faking" a type bound procedure, there should be no problem in creating the abstract interfaces, I don't think it is something that the "standard requires".
(2) If I am 90% sure of what the language standard is about the previous point, I am not so sure for the this one...In particular, this has to with the order in which the type and interface is specified. The abstract interface, although used in the procedure pointer component's interface specification, is AFTER the type declaration and yet the type has no problems accepting it.... We cannot put the abstract interface before the type declaration since it imports the type defintion. Then, why, if I may ask, can't one just ommit the Abstract Interface declaration? That is why can't the interface to the procedure, in this case, subroutine Display, be directly used? The procedure is in the same module and if the type can "wait" and then resolve the procedure component interface through abstract interface why not through the module's procedure?
Abhi
abhimodak
I also find that if I don't inlcude "iSomethingElse" in the interface to the procedure, I get an internal compiler error.
More specifically, the subroutine Display has only one argument and that is the object of type MyType. The procedure pointer component is still give the attribute "Pass". When the call is made from the program, it is simply Trial%Show since no argument needs to be passed.
With this change I get: fortcom: Fatal: There has been an internal compiler error (C0000005).
If I used NoPass instead and make a corresponding change to call, the building (and execuation) is successful.
Abhi
Kevin_D_Intel
Hi Abhi,
I am still learning about this and other F2003 features and after some further reading; I concur with you about (1) and am seeking some guidance regarding yours questions in (2).
I suspect all of the internal errors are related and will code up the third variant per your description and include that in the report to the Fortran Front-end developer. It is possible some or all of the variants will work after the internal error is fixed. I will keep you posted. (Internal ref. CQ-50185)
Kevin
abhimodak
Kevin
I appreciate you entertaining this post and following up on it. I would be looking for to testing the new beta version when (and if) that is available.
The abstract interface and passing a dummying argument (or using NoPass) is an work-around that is good enough at present.
Abhi
Kevin_D_Intel
Hi Abhi,
This issue is fixed in the latest 11.0 update, 11.0.072 (Windows). It is also included in the latest Linux/Mac OS updates 11.0.081/11.0.059.
