29649 Discussions
Procedure pointer as function result ?
gregory_lantoine
Hello all,
I'm using Visual Fortran 11 on Windows 32 and I found a problem when I'm trying to use a procedure pointer as a result of a function. I'm getting the error 'Program Exception - access violation'. Here is the code:
[cpp]
PROGRAM MAIN
use TestMod
implicit none
type(object_ptproc) ptproc
external DummyFunc
    ptproc = test_ptproc(DummyFunc)
    call ptproc%pt(2)
END PROGRAM MAIN
subroutine DummyFunc(n)
implicit none
integer, intent(in) :: n
print*, n
end subroutine DummyFunc
[/cpp]
module TestMod abstract interface subroutine OutputFunc(n) integer, intent(in):: n end subroutine OutputFunc end interface type object_ptproc procedure(OutputFunc), nopass, pointer :: pt => NULL() end type object_ptproc CONTAINS function test_ptproc(OutputFcn) result(ptproc) implicit none type(object_ptproc) :: ptproc external OutputFcn ptproc%pt => OutputFcn end function test_ptproc end module TestMod
However, when I use a subroutine instead of a function, it's working fine :
[cpp]PROGRAM MAIN
use TestMod
implicit none
external DummyFunc
    call test_ptproc(ptproc,DummyFunc)
    call ptproc%pt(2)
END PROGRAM MAIN
implicit none
print*, n
module TestMod
        abstract interface
	end interface
	type object_ptproc
	CONTAINS
	subroutine test_ptproc(ptproc,OutputFcn)
	implicit none
	type(object_ptproc), intent(out) :: ptproc
	external OutputFcn
	end subroutine test_ptproc
end module TestMod[/cpp]
Do you think this is a bug of Visual Fortran ? If so, can it be corrected ?
Thanks a lot in advance !
Gregory
gregory_lantoine
Sorry, there was a problem when I copy-pasted the first code. Here is the right one:
PROGRAM MAIN
use TestMod
implicit none
external DummyFunc
call ptproc%pt(2)
END PROGRAM MAIN
implicit none
print*, n
module TestMod
abstract interface
end interface
type object_ptproc
CONTAINS
implicit none
external OutputFcn
end module TestMod
It's a compiler bug. In version 11.0, test_ptproc is not returning the pointer correctly. This is fixed in version 11.1, coming out in a few months.
