Procedure pointers as an OPTIONAL function argument
Michael_D_11
I am developing a project where a function makes use of an optional procedure pointer. Since the procedure pointer is OPTIONAL, an explicit interface is required. In other situations where I needed an interface block I typically made use of the auto-generated interface obtained during compilation of the procedure of interest. In my current case, this doesn't work as the compiler gives an error when compiling the interface block (as a module). For example, given the main program foo:
program foo
   use tfunct
   use BAR__genmod
   implicit none
   abstract interface
      function test(a, b, c)
         real                :: test
         integer, intent(IN) :: a
         real, intent(IN)    :: b
         real, intent(IN)    :: c
      end function test
   end interface
   integer a
   real b, c, d
   procedure(test), pointer :: ofunc
   ofunc => aTest
   a = 2; b = 5.0; c = 7.0
   call bar(a,b,c,d,ofunc)
   print *,d
   call bar(a,b,c,d)
   print *,d
end program foo
The function bar is in a separated module with the auto-generated interface BAR__genmod:
!COMPILER-GENERATED INTERFACE MODULE: Tue Nov 14 11:36:38 2017
! This source file is for reference only and may not completely
! represent the generated interface used by the compiler.
MODULE BAR__genmod
   INTERFACE
   SUBROUTINE BAR(A,B,C,X,OFUNC)
      INTEGER(KIND=4), INTENT(IN) :: A
      REAL(KIND=4), INTENT(IN) :: B
      REAL(KIND=4), INTENT(IN) :: C
      REAL(KIND=4), INTENT(OUT) :: X
      INTERFACE
         FUNCTION OFUNC(A,B,C)
         REAL(KIND=4) ,OPTIONAL :: OFUNC
         END FUNCTION OFUNC
      END INTERFACE
   END SUBROUTINE BAR
   END INTERFACE
END MODULE BAR__genmod
and the ofunc points to aTest in the module tfunct, and aTest has the same interface as shown in the two files above.
When compiled, I get the following: error #6413: This global name is invalid in this context.   [OFUNC]
I understand the error, but don't understand how the compiler generated an invalid interface nor what the proper interface would look like. I realize that as a fallback I could always access the function foo through a module and use association, but I rather not use that approach.
Any insight would be appreciated.
JVanB
Valued Contributor II
Actually, we need the specification part of subroutine bar to be able to write a proper interface. Assuming dummy argument OFUNC to procedure bar is actually a procedure pointer and not a procedure, the interface body should look something like this:
MODULE BAR__genmod
   INTERFACE
      ABSTRACT INTERFACE
         FUNCTION OFUNC_PROTOTYPE(A,B,C)
         REAL(KIND=4) :: OFUNC_PROTOTYPE
         END FUNCTION OFUNC_PROTOTYPE
      END INTERFACE
      PROCEDURE(OFUNC_PROTOTYPE), OPTIONAL, POINTER :: OFUNC
   END SUBROUTINE BAR
   END INTERFACE
JVanB
MODULE BAR__genmod
   INTERFACE
      ABSTRACT INTERFACE
      END INTERFACE
   END SUBROUTINE BAR
   END INTERFACE
Michael_D_11
OFUNC is a procedure pointer and your suggestion works perfectly. Thanks much for the assistance - I doubt I would have ever stumbled on this way of writing the interface.
JVanB
Cool. Another syntax that I think should work is:
MODULE BAR__genmod
   INTERFACE
      INTERFACE
         END FUNCTION OFUNC
      END INTERFACE
      OPTIONAL :: OFUNC
      POINTER :: OFUNC
   END SUBROUTINE BAR
   END INTERFACE
The above is accepted by gfortran but ifort 16.0.2 produces the following error message:
bar1.f90(20): error #6429: This name has already been used as a dummy function n
ame.   [OFUNC]
      POINTER :: OFUNC
compilation aborted for bar1.f90 (code 1)
Is this fixed in the latest version of ifort?
andrew_4619
In answer to #4, No
Compiling with Intel(R) Visual Fortran Compiler 18.0.0.124 [IA-32]...
dbug_parms.f90
C:\Users\...\dbug_parms\dbug_parms.f90(37): error #6429: This name has already
been used as a dummy function name.   [OFUNC]
compilation aborted for C:\Users\...\dbug_parms\dbug_parms.f90 (code 1)
