29386 Discussions
Procedures as arguments and setting dummy arguments
vrotival
Hello everyone
I am quite experienced with FORTRAN but I really have problems with this issue.
I am trying to make the following code, where I want to use something like function overloading, by setting one argument of one function to a definite value when it is called (see NON working line)
I do not want to put the variable a as a global one for parallel-processing reasons, but I cannot think of any way to make this code work
Any help would be greatly appreciated
Best regards
Vincent
program dbg
implicit none
integer, parameter :: N = 10
real, dimension(N) :: xval
real :: junk
integer :: i
interface
function f1(x) result(res)
implicit none
real :: x, res
end function f1
end interface
interface
function f2(x, a) result(res)
implicit none
real :: x, res, a
end function f2
end interface
do i = 1, N
xval(i) = (i-1.)/N*5.
print *, "INIT :", xval(i), f1(x=xval(i)), f2(x=xval(i), a=2.)
end do
call print_values(xval, N, f=f1)
! call print_values(xval, N, f=f2(SOMETHING, a=2.)) <=== WILL NOT WORK
contains
subroutine print_values(x, npts, f)
implicit none
interface
function f(x) result(res)
implicit none
real :: x
real :: res
end function f
end interface
real :: junk
integer :: i, npts
real, dimension(:) :: x
do i = 1, npts
junk = f(x(i))
print *, x(i), junk
end do
end subroutine print_values
end program dbg
real :: res, x
res = 2.*x
end function f1
real :: res, x
real :: a
res = 2.*x*a
end function f2
I don't think I have anything to add to what you were told in comp.lang.fortran about this.
clabra
Steve,
I use this kind of "tricks", but I have a question. The compiler is capable of make the inlining of this routine, even if I call several times the subroutine with different procedure argument ??
I don't quite understand your question - the compiler will decide on inlining on a per-call (in the source) level - it doesn't decide dynamically during execution.
clabra
I know the inline is a compile time, but sometimes it is possible the inline.
In the next sources:
program dbg
implicit none
real :: junk
integer :: i
interface
implicit none
real :: x, res
end function f1
function f2(x) result(res)
implicit none
real :: x, res
end function f2
end interface
do i = 1, N
print *, "INIT :", xval(i), f1(xval(i)), f2(xval(i))
end do
call print_values(xval, N, f=f2)
contains
implicit none
interface
implicit none
real :: x
real :: res
end function f
end interface
real :: junk
integer :: i, npts
do i = 1, npts
junk = f(x(i))
print *, x(i), junk
end do
end program dbg
real :: res, x
res = 2.*x
end function f1
real :: res, x
res = 3.*x
end function f2
compiling with optimization report, the result show the functions inlined. The question is: always its possible or just in some specific cases??
INLINING REPORT: (MAIN__) [1/4=25.0%]
-> INLINE: dbg_.print_values_(7) (isz = 45) (sz = 54 (17+37))
-> INLINE: f2_(9) (isz = 2) (sz = 7 (3+4))
-> for_write_seq_lis(EXTERN)
-> for_write_seq_lis_xmit(EXTERN)
-> INLINE: dbg_.print_values_(4) (isz = 45) (sz = 54 (17+37))
-> INLINE: f1_(6) (isz = 2) (sz = 7 (3+4))
-> INLINE: f2_(8) (isz = 2) (sz = 7 (3+4))
-> INLINE: f1_(5) (isz = 2) (sz = 7 (3+4))
-> for_set_reentrancy(EXTERN)
Inlining is not always possible. The compiler makes a decision based on how large the called routine is, what registers it might use, how often it thinks the routine is to be called, etc.
clabra
my mistake. I make the question in other way.
This kind of routines ( as argument ) have the same treatment for the inlining ?? or is most complicate for the compiler analyze it ??
You can see in the report output that you posted that first the print routine got inlined (twice) and then the calls to f1 and f2 got inlined respectively. The compiler will do this sort of recursive inlining until it no longer makes sense, from its perspective.
In this case, the compiler knew exactly what the argument was - a routine. This in itself didn't affect the inlining of the print routine. It could then figure out that f1 and f2 were being called and it could inline those, as they were small.
I would say that in general the more code needed to evaluate an argument, the less likely inlining is, but simple argument types should not matter much.
