29649 Discussions
Profiling remotely applications on linux server from MacOS
gmadison
Any ideas on how to profile applications on a linux server from MacOS?
Right now I am using ssh to a Dell R820 server in my garage, I can setup X11 on the server and my Mac supports X11 clients if I need to. But command line tools are fine.
Ron_Green
Vtune supports remote profiling from mac client to a linux server.  But it's cumbersome as you have to have the sources and objects in both places and synchronized.  I've found it far more simple to just ssh -Y to get X11 forwarding.  Assuming you set up X11.   oneAPI does not need licensing so you could set up Vtune on the Linux server and your mac.  Vtune is in the oneAPI Basekit.  and as you know the compilers are in the oneAPI HPC Toolkit.  No reason to not load it up on both systems.
Ron_Green
