29592 Discussions
Program Exception - access violation
Omar_M_1
I am running some simulation software written in Fortran while using Matlab to automate the simulations. The simulations run through, but I keep getting this error very frequently while the program is running:
 forrtl: severe (157): Program Exception - access violation
 Image                              PC                       Routine                  Line          Source
 Simulate.exe       000000013F473F2B     Unknown               Unknown    Unknown
 Simulate.exe       000000013F473BDC    Unknown               Unknown    Unknown
 Simulate.exe       000000013F4DF4BC    Unknown               Unknown    Unknown
 Simulate.exe       000000013F4C80F6     Unknown               Unknown    Unknown
 kernel32.dll         00000000773559CD     Unknown               Unknown    Unknown
 ntdll.dll                000000007758B981      Unknown               Unknown    Unknown
From what I found online, this error apparently means that I am using memory that I am not supposed to. However, I am puzzled by how it's reporting "unknown" for the Routine, Line, and Source. Any suggestions on how to deal with this?
Kevin_D_Intel
The traceback symbolization may be missing due not enabling generation of debugging information.
If compiling via the ifort command line, try adding: /debug
If compiling under the IDE, look for:  General > Debug Information Format
There's additional information about the debug option in the Fortran UG here.
Actually you need to enable the traceback feature for this - it doesn't use the debug info. /traceback from the command line, or Run Time > Generate Traceback Information in Visual Studio.
