29653 Discussions
Protected array variables and submodules
Johannes_R_
The following code is modified from https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/610969.
module mymod
  implicit none
  integer, protected :: n
  integer, protected :: m(1)
  interface
     module subroutine set(i)
       integer, intent(in) :: i
     end subroutine set
  end interface
end module mymod
submodule(mymod) mymod_i
contains
    n = i          ! OK
    m = i          ! OK
    m(1) = i       ! ERROR #7986
    call foo(m(1)) ! ERROR #7993
  end subroutine set
  subroutine foo(x)
    integer, intent(out) :: x
    x = 10
  end subroutine foo
end submodule mymod_i
program test
  use mymod
  implicit none
  integer :: i
  i = 5
  call set_n(i)
  print *,n
end program test
This fails to compile:
$ ifort test.f90 -o test
test.f90(18): error #7986: A use associated object that has the PROTECTED attriute shall not appear in a variable definition context.
test.f90(19): error #7993: A use associated object that has the PROTECTED attriute shall not appear as an actual argument if the associated dummy argument hasthe INTENT(OUT) or INTENT(INOUT) attribute.
compilation aborted for test.f90 (code 1)
$ ifort --version
ifort (IFORT) 17.0.1 20161005
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
There was previously a compiler bug, now fixed, which prevented the "n" protected variable from being set in the submodule. It seems this problem still occurs for arrays.
FortranFan
" It seems this problem still occurs for arrays." - it's unfortunate, hopefully this will be fixed in the near future.
Kevin_D_Intel
Thank you for reporting this variant. I escalated it to our Developers.
(Internal tracking id: DPD200418117)
