Puzzling compiler error msg
WSinc
I get error #6008 when I compile this.
How then should I initialize these arrays?
except by copying arrays from some other locations that are not in the module.
Actually I dont understand why DATA statements would be a problem here.
See attached routine.
IanH
To allow this to compile reliably, you want the compiler to see the source code for the module before it sees the source code for things that `use` the module.
Note that DATA specifies initialization.  Initialization is something that conceptually happens before the program starts executing.
Bar some exceptions not relevant here, when something is defined in a module the "totality" of its definition is provided in the module.  The initialization value of something is part of its definition (as is the implied SAVE status that DATA gives to the thing being initialized, when that's applicable) - after all a thing can only be initialized once.
With your example code you've got that definition split across two program units - in the module you define the type and size of mxcom and ncom, in the main program you provide the initialization details.
To highlight - consider this erroneous snippet:
MODULE m
  IMPLICIT NONE
  INTEGER :: some_variable
END MODULE m
SUBROUTINE a
  USE m
  IMPLICIT NONE
  DATA some_variable/1/
END SUBROUTINE a
SUBROUTINE b
  USE m
  IMPLICIT NONE
  DATA some_variable/2/
END SUBROUTINE b
Before a program that holds this code starts executing, is the initial value of some_variable 1 or 2?  Conceptually this doesn't work - hence it is illegal.
Note that initialization (happens before the program starts executing) is different from "an assignment that happens early on in the execution of a program or subroutine".  If your example was rewritten:
  module sud003
  IMPLICIT NONE
  integer mxcom(9)
  integer ncom(9)
  end module
  use sud003
  IMPLICIT NONE
  mxcom = 20      ! Assign the value 20 to all elements.
  ncom = 0        ! Assign the value 0 to all elements.
  call newbox(1)
  print *,"DONE"
  read(*,*)
  end program
then you shouldn't get any complaints for that part of the code.
WSinc
Fine except:
1) I was under the impression the DATA statements are supposed to initialize everything BEFORE
execution begins, and
2) The whole point of putting the DATA statement in the MAIN program was to take care of all that
initialization ahead of time, and finally:
3) The MODULES are supposed to be compiled first anyway.
It isnt clear to me what would happen IF i put the data statements in the module statements.
Can Steve give his input here?
Please?
Fortran has a rule that prohibits changing attributes of an identifier made accessible by use or host association. (There are a couple of exceptions to this not relevant to your question.) DATA is specifying an initialization attribute of the variable, it isn't an executable construct. Therefore if you want to use DATA for these variables you must place the DATA declarations in the same module where the variable is declared. (Or you can use an initializer in the declaration itself rather than DATA.)
WSinc
OK, that makes sense -
I normally would put the MODULES in separate files, but I wanted to keep this example as simple as I could.
So I should put my DATA statements in the same file as the MODULE that has the variables.
Thanks ! !
Not only the same file, but in the same module (or even right after the declaration of the variable).
