Puzzling error message - BUG?
WSinc
I get this "recursive I/O operation" breakpoint.
Are there ANY rules that prevent me from priniting out the function value as an intermediate result?
It runs OK if I comment out the second print statement near the end.
It might be related to having that array in COMMON rather thanhaving it as input argument.
Why does it say "UNIT -1" - - does that even exist?
That why it seems peculiar, anyway.
program test4
integer*1 p(10)/10*10/
integer*8 prod,prod1
common/com1/p
print *,"prod=",prod()
read(*,*)
end program
integer*8 function prod()
common/com1/p
integer*1 p(10)
prod=1
do i=1,10
prod=prod*p(i)
print *,"i=",i," prod=",prod
end do
end
It is a bug in your code, yes. The Fortran standard prohibits starting an I/O operation on a unit while another operation on that unit is in progress. PRINT implies a specific unit. You have a reference to prod() in the PRINT in the main program and prod also does a print - this will result in the "recursive I/O error".
WSinc
Even when it's a console unit?
How would I modify this so that I can print out an intermediate result (for debugging) anyway.
BTW, is there a way to make the forum letters a little larger?
I don't see an option for that.
mecej4
Avoid expressions in I/O lists that contain references to functions that do I/O. For example, instead of
do
prod1 = prod()
print *, "prod=",prod1
You can use WRITE(6,*) as a replacement for PRINT *, in the function. This will use a separate unit.
Les_Neilson
Valued Contributor II
If you are using IE to access the forum then from the menu View->Text Size-> you have a choice from Largest to Smallest
Les
Ignore that I've just tried it and it made no difference. Strange.
David_Kinniburgh
On Windows, you could use the generic Cntrl-+, Cntrl-- and Cntrl-0 for changing text size (hold down Cntrl then press + etc)
In Firefox, you can use View > Zoom for this and it does work.
WSinc
Those don't change the text size relative to the window, but still the
zoom is good for senior eyes like mine.
Thanx for suggestion ! ! !
Actually, another answer rather than WRITE(6,*) is to put the function value
in a temporary variable, then print that out instead.
