Q about building X64 DLLs
DavidWhite
Valued Contributor II
I'm just starting trying to migrate my Win32 DLLs to x64.
When I run dependency walker on my DLL's it reports that it found different modules with different CPU types.  As I am not yet able to test these DLL's with their intended x64 apps - I assume that this error means that they will not run correctly.  Is that right?
David
FortranFan
David
Can you confirm you're using a 64-bit tool such as 64-bit Depends.exe to check the DLL dependencies?
TimP
It's normal to allow on PATH  (and ignore) .dlls with the wrong /machine setting.  You will need .dlls with the correct setting in place of or in addition to those others.  I suppose Dependency Walker would select the correct ones if present (which they may not be, if building on a 32-bit Windows).
In the past, we've seen tools for building .dll (not from Microsoft or Intel) which failed to set /machine even though building from X64 .obj files.  Such .dlls will be ignored, not used (or used, but fail, with a 32-bit build).
FortranFan
David
DependencyWalker doesn't follow Windows' rules for how DLLs are located on PATH. It doesn't understand the skipping of "wrong architecture" DLLs on an x64 system.
DavidWhite
The x64 version of dependency walker reports "x64" for all loaded DLL's.
