QSORT Problem
Glynn_H_
UBROUTINE call_qsort
I'm having some problems with the QSORT subroutine. I have some code along the lines of the given below. The user-defined ordering function is called "compare".
    SUBROUTINE call_qsort
        USE IFPORT
        IMPLICIT NONE
        INTEGER :: nlett
        CHARACTER (3), ALLOCATABLE :: templett(:)
  INTEGER (kind=2), EXTERNAL :: compare
        ! .. External Functions ..
        nlett = 10
        ALLOCATE(templett(nlett))
        templett = ...
  CALL qsort(templett,nlett,3,compare)
END SUBROUTINE call_qsort
FUNCTION compare(a,b)
    IMPLICIT NONE
    INTEGER (kind=2) :: compare
    CHARACTER (3) :: a, b
    INTRINSIC LGT
    IF (LGT(a,b)) THEN
        compare = 5
    ELSE IF (LGT(b,a)) THEN
        compare = -5
    ELSE
        compare = 0
    END IF
END FUNCTION compare
When I run the code I get the error
Fort: (18): Dummy character variable ‘B’ has length 3 which is greater than actual variable length 1
Does anyone have an idea of what is going wrong - have I missed something obvious?!
Your compare routine is being called with a single character passed for the second argument. Offhand I don't see why that would happen but my guess is that it relates to code you omitted. Ordinarily I'd recommend using CHARACTER(*) in the dummy argument declaration of B, but you should try to figure out why it is getting only one character.
