Qopenmp-link:static not supported
tropfen
for an older version of IVF (11.1.xxx) i had the need to add the following option: Qopenmp-link:static.
Using the current version (13.1.1.171) i get the warning 'Qopenmp-link:static not supported'.
For the old version i explicitly needed the option to include the needed 'MP' files into the exe-files. Are those files automaticlly included with the current version?
Thanks in advance
Frank
For our Windows compilers, the OpenMP library is now provided in DLL form only. This is called out in the release notes. There have also been warnings in the release notes in some previous versions (though not as far back as 11.1) that the static library was going away.
tropfen
Hello Steve,
the change from lib to dll is one point. The other is, is it needed to add those dll files if i distribute the exe file or are all needed parts from those dll files added to the exe file?
Thanks in advance
Frank
You need to distribute the DLL separately.
Sorry, it is not possible. But you should just be able to copy libiomp5md.dll alongside your EXE. You don't have to use the msi. Nothing else is needed.
