Question
JNichols
When I open a SLN file in VS 2022 I get the following error for files that were not closed when I closed the sln file.  It is now happening in VS 2019
Anyone got any ideas if it is a VSIX Fortran problem or a VS problem?
GVautier
New Contributor III
Is double Prime6 directory in path normal?
JNichols
Yes, I had a look on google and found the following
Why your Visual Studio add-in fails to load with error 0x80004005 - Developer Support (microsoft.com)
It is an old problem that is well known, this suggests a mistake in the Fortran addins,...
jimdempseyatthecove
That could possibly be a file in (exclusive) use.
What happens if you logout/login?
What happens if you reboot? (I know you don't want to do this, but it can provide useful information for diagnosis).
Does this help: https://www.lifewire.com/how-to-fix-error-code-0x80004005-4689559
Jim Dempsey
JNichols
The problem is it is happening on three computers, running different operating system versions, I cannot believe it would happen on a NUC, Lenova and a HP at the same time as soon as I loaded oneAPI and VS 2022 and started using the program. This is to much of a coincidence.
