29649 Discussions
Questions about fortran constructions
Averkov__Igor
Hello!
Please answer some questions about fortran construction
1. I have a function:
function GetArgumentName() result(Res)
    character(250) Res
end function
How can i use substring of first character without declaring additional variables like this:
GetArgumentName()(1:1)
Compiler don't let me so
2. I have a function:
function GetArray()  result(Res)
  integer(1:100) Res
end function
Why compiler do not let me use the following expression:
n = 5 + GetArray()(1)
where i want to add to 5 the first element of the array?
3. I have a type and a function:
type T_Point
 real X, Y
end type
function GetPoint() result(Res)
  type(T_Point) Res
end function
r = 5.0 + GetPoint() % X
Is it really necessary to declare auxiliary variables every time to execute these expressions?
Steve_Lionel
It's the Fortran language that does not allow you to do those things, not the compiler. A function reference isn't a data object that can be itself qualified with subobjects.
Averkov__Igor
Thank you very much Steve
FortranFan
Averkov, Igor wrote:
Please answer some questions about fortran construction ..
 .. use the following expression:
r = 5.0 + GetPoint() % X.
As stated upthread, the Fortran standard does not allow your to use function references the way you want.
However look into ASSOCIATE construct: https://software.intel.com/en-us/fortran-compiler-developer-guide-and-reference-associate
ASSOCIATE can prove very valuable in situations where you need to associate objects and their subobjects or function results, see below.  While you're at it. you may want to look at BLOCK construct in Fortran also: https://software.intel.com/en-us/fortran-compiler-developer-guide-and-reference-block
   type :: T_Point
      real :: x = 0.0
      real :: y = 0.0
   end type
   blk2: block
      integer :: n
      asc2: associate ( Array => GetArray() )
         n = 5 + Array(1)
         print *, "Associate 2: n = ", n, "; expected is 47"
      end associate asc2
   end block blk2
   blk3: block
      real :: n
      asc3: associate ( Pt => GetPoint() )
         n = 5.0 + Pt%X
         print *, "Associate 3: n = ", n, "; expected is 6.0"
      end associate asc3
   end block blk3
   asc1: associate ( ArgName => GetArgumentName() )
      print *, "Associate 1: ArgName(1:1) = ", ArgName(1:1)
   end associate asc1
contains
   function GetArgumentName() result(ret)
      ! Function result
      character(len=250) :: ret
      ret = "Hello World!"
   end function
      ! Function result
      integer :: Res(1:100)
      Res = 42
   end function
      ! Function result
      type(T_Point) :: Res
      Res%X = 1.0 ; Res%Y = 2.0
   end function
end
Upon execution, the first two work ok.  Intel Fortran compiler gives a compile time warning and then crashes at run-time with the CHARACTER object result from a function, both a bug me thinks:
C:\Temp>ifort /standard-semantics /warn:all /check:all /stand:f18 /warn:stderrors /traceback p.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64,
Version 19.1.0.056 Pre-Release Beta Build 20190321
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
ifort: NOTE: The Beta evaluation period for this product ends on 9-oct-2019 UTC.
p.f90(23): warning #5481: Variable ARGNAME has substring ending point 1 which is
greater than the variable length of 0
Microsoft (R) Incremental Linker Version 14.16.27027.1
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
-incremental:no
p.obj
C:\Temp>p.exe
 Associate 2: n =  47 ; expected is 47
 Associate 3: n =  6.000000 ; expected is 6.0
forrtl: severe (408): fort: (12): Variable ARGNAME has substring ending point 1 which is
Image              PC                Routine            Line        Source
p.exe              00007FF606D0C611  Unknown               Unknown  Unknown
p.exe              00007FF606D014C3  MAIN__                     23  p.f90
p.exe              00007FF606D50DE2  Unknown               Unknown  Unknown
p.exe              00007FF606D517B4  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFD429B37E4  Unknown               Unknown  Unknown
ntdll.dll          00007FFD42DECB81  Unknown               Unknown  Unknown
C:\Temp>
DataScientist
Valued Contributor I
@FortranFan Thanks for your comment. That feature is very elegant. However, here is another question: when one associates a function with a name, and the name is used in the association block, is the function going to be called every time, or is it called only once upon entry to the associate construct?
FortranFan
In principle, the evaluation of the expression based on the function reference should only take place once during the association of the entity (e.g., Pt above) with the selector.  Note where the selector (e.g., GetPoint() above) is not a variable, as in say a function reference, or is otherwise not allowed to be in a variable definition context, the associating entity and any of its subobjects, if applicable, cannot be present in a variable definition context either, like on the left-hand side of an assignment.  Such requirements on the coder allow a compiler not to invoke a function any further during the execution of the block i.e., the instructions between "associate(..)" and "end associate".
Hope this helps,
jimdempseyatthecove
You also have available the now depreciated statement function.
Or you can write a Get function:
type T_Point
 real X, Y
end type
  type(T_Point) Res
end function
function GetX(p) result(Res)
  type(T_Point) :: p
  real :: Res
  Res = p%x
end function GetX
something = GetX(GetPoint())
Jim Dempsey
