Questions from a beginner
tang_1949
I installed the Intel Visual Fortran a few months ago but didn't get a chance to run it till today. I used tocompile Fortran programs in Linux andcame upon a couple of problemsfor running Intel VF inWindows.
(1) When I debug the program, the print out just flashed in a command window and disappeared. How can Iview the printout so that I can monitor the run?
(2) I tried to use the program in the command line,such as "ifort /c test.f90". But I got an error message as:
'command "ifort" is not valid'.
Now I am stuck. Thanks in advance.
If you select "Start without debugging" from the Debug menu, the console window will remain open after the program exits. Otherwise, set a breakpoint on the END statement of your program so that when you run under the debugger, the window will still be there (untiil you proceed from the breakpoint.)
TimP
The preferred way to run the compiler from command line is to find the Intel Software entry on the start menu, and open the Fortran Build environment. You should also be able to run your program in this window.
tang_1949
Quoting - tim18
Tim,
Thanks for the reply! However, I don't understand a bit of it as a beginner.
I wish I could view the printout as the program is running or just ran. Otherwise I have to output some results in a text file in order to checkthe programdid as it was supposed to do.
Best.
Gong
Les_Neilson
Valued Contributor II
Quoting - tang_1949
Tim,
Best.
Gong
Gong,
You need to open a console window.
At the bottom left (usually) of the screen there is a "Start" button
If you click on that then a menu of items appears - one of which is "Programs"
Click on "Programs"
Find the item "Intel Software Development Tools"
Click on that
Clck the "Intel Fortran Compiler ..." you installed
Click "Build Environment for Fortran ..."
This will open a console window with the necessary paths set
You should now be able to change directory to where your program executable is and run it and/or compile it.Any messages will appear in the console window.
Les
tang_1949
Quoting - Les Neilson
Gong,
Click on "Programs"
Click on that
Les
Les,
Thanks for the information! I was able to run the program and see the output in the console window. However, I still wonder if there is a way that I can see the output in a window when I am running the program in the Microsoft Visual Studio IDE.
Gong
tang_1949
Quoting - tang_1949
I appreciate inputs from all!!!
Gong
