QuickWin App: Run Time Error
ivomar
Some days ago, I asked the Compaq Visual Fortran Support if they knew a way to control run
time error, rehabilitating the external callbacks of a program, and he told
me that not. I informed
that I made that by placing MODIFYMENUFLAGSQQ inside the infinite loop, but their
answer was:
"Putting MODIFYMENUFLAGSQQ in the loop doesn't help - if the application
exits,
your main program is terminated and all user menu items are disabled".
Then, I enclosed the source code with an example in an email, but I didn't
obtain any answer.
That?s why I ask: Is there a more efficient way of rehabilitating external
callbacks from run time error?
james1
Yes, you need to do some exception handling. In the case you provided, you could for example add the routine:
SUBROUTINE MATHERRQQ( name, length, info, retcode)
USE DFLIB
INTEGER(2) length, retcode
CHARACTER(length) name
RECORD /MTH$E_INFO/ info
retcode = 1
END
to the provided program which would prevent the thread from terminating. Just add whatever code is suitable to handle the error.
James
